Overview
This subordinate charm provides the Neutron OpenvSwitch configuration for a compute node.
Once deployed it takes over the management of the Neutron base and plugin configuration on the compute node.
Important: This documentation supports version 3.x of the Juju client.
See the OpenStack Charm
guide if you are using the 2.9.x client.
Usage
To deploy (partial deployment of linked charms only):
juju deploy rabbitmq-server
juju deploy neutron-api
juju deploy nova-compute
juju deploy neutron-openvswitch
juju integrate neutron-openvswitch nova-compute
juju integrate neutron-openvswitch neutron-api
juju integrate neutron-openvswitch rabbitmq-server
Note that the rabbitmq-server can optionally be a different instance of the rabbitmq-server charm than used by OpenStack Nova:
juju deploy rabbitmq-server rmq-neutron
juju integrate neutron-openvswitch rmq-neutron
juju integrate neutron-api rmq-neutron
The neutron-api and neutron-openvswitch charms must be related to the same instance of the rabbitmq-server charm.
Restrictions
It should only be used with OpenStack Icehouse and above and requires a separate neutron-api service to have been deployed.
Disabling security group management
WARNING: this feature allows you to effectively disable security on your cloud!
This charm has a configuration option to allow users to disable any per-instance security group management; this must used with neutron-security-groups enabled in the neutron-api charm and could be used to turn off security on selected set of compute nodes:
juju deploy neutron-openvswitch neutron-openvswitch-insecure
juju config neutron-openvswitch-insecure disable-security-groups=True prevent-arp-spoofing=False
juju deploy nova-compute nova-compute-insecure
juju integrate nova-compute-insecure neutron-openvswitch-insecure
These compute nodes could then be accessed by cloud users via use of host aggregates with specific flavors to target instances to hypervisors with no per-instance security.
Network Spaces support
This charm supports the use of Juju Network Spaces, allowing the charm to be bound to network space configurations managed directly by Juju. This is only supported with Juju 2.0 and above.
Open vSwitch endpoints can be configured using the ‘data’ extra-binding, ensuring that tunnel traffic is routed across the correct host network interfaces:
juju deploy neutron-openvswitch --bind "data=data-space"
alternatively these can also be provided as part of a juju native bundle configuration:
neutron-openvswitch:
charm: cs:xenial/neutron-openvswitch
bindings:
data: data-space
NOTE: Spaces must be configured in the underlying provider prior to attempting to use them.
NOTE: Existing deployments using os-data-network configuration options will continue to function; this option is preferred over any network space binding provided if set.
DPDK fast packet processing support
For OpenStack Mitaka running on Ubuntu 16.04, it’s possible to use experimental DPDK userspace network acceleration with Open vSwitch and OpenStack.
Currently, this charm supports use of DPDK enabled devices in bridges supporting connectivity to provider networks.
To use DPDK, you’ll need to have supported network cards in your server infrastructure (see [dpdk-nics][DPDK documentation]); DPDK must be enabled and configured during deployment of the charm, for example:
enable-dpdk: True
data-port: "br-phynet1:a8:9d:21:cf:93:fc br-phynet2:a8:9d:21:cf:93:fd br-phynet3:a8:9d:21:cf:93:fe"
As devices are not typically named consistently across servers, multiple instances of each bridge -> mac address mapping can be provided; the charm deals with resolution of the set of bridge -> port mappings that are required for each individual unit of the charm.
DPDK requires the use of hugepages, which is not directly configured in the neutron-openvswitch charm; Hugepage configuration can either be done by providing kernel boot command line options for individual servers using MAAS or using the ‘hugepages’ configuration option of the nova-compute charm:
nova-compute:
hugepages: 50%
By default, the charm will configure Open vSwitch/DPDK to consume a processor core + 1G of RAM from each NUMA node on the unit being deployed; this can be tuned using the dpdk-socket-memory and dpdk-socket-cores configuration options of the charm. The userspace kernel driver can be configured using the dpdk-driver option. See config.yaml for more details.
NOTE: Changing dpdk-socket-* configuration options will trigger a restart of Open vSwitch, which currently causes connectivity to running instances to be lost - connectivity can only be restored with a stop/start of each instance.
NOTE: Enabling DPDK support automatically disables security groups for instances.
DPDK bonding
For deployments using Open vSwitch 2.6.0 or later (OpenStack Ocata on Ubuntu 16.04 onwards), it’s also possible to use native Open vSwitch DPDK bonding to provide increased resilience for DPDK based deployments.
This feature is configured using the dpdk-bond-mappings and dpdk-bond-config options of this charm, for example:
enable-dpdk: True
data-port: "br-phynet1:dpdk-bond0"
dpdk-bond-mappings: "dpdk-bond0:a8:9d:21:cf:93:fc dpdk-bond0:a8:9d:21:cf:93:fd"
dpdk-bond-config: ":balance-slb:off:fast"
In this example, the PCI devices associated with the two MAC addresses provided will be configured as an OVS DPDK bond device named dpdk-bond0; this bond device is then used in br-phynet1 to provide resilient connectivity to the underlying network fabric.
The charm will automatically detect which PCI devices are on each unit of the application based on the dpdk-bond-mappings configuration provided, supporting use in environments where network device naming may not be consistent across units.
Port Configuration
Note: External port configuration only applies when DVR mode is enabled. This may not work when
neutron-openvswitchis deployed in a LXD container. If your deployment requires mixed placement ofneutron-openvswitchunits, add multiple application instances with different names to your model to allow for separate configuration. You can view examples of this configuration in the Octavia Charm functional test gate bundles.
All network types (internal, external) are configured with bridge-mappings and data-port and the flat-network-providers configuration option of the neutron-api charm. Once deployed, you can configure the network specifics using neutron net-create.
If the device name is not consistent between hosts, you can specify the same bridge multiple times with MAC addresses instead of interface names. The charm will loop through the list and configure the first matching interface.
Basic configuration of a single external network, typically used as floating IP addresses combined with a GRE private network:
bridge-mappings: physnet1:br-ex
data-port: br-ex:eth1
neutron-api:
flat-network-providers: physnet1
neutron net-create --provider:network_type flat \
--provider:physical_network physnet1 --router:external=true \
external
neutron router-gateway-set provider external
Alternative configuration with two networks, where the internal private network is directly connected to the gateway with public IP addresses but a floating IP address range is also offered.
bridge-mappings: physnet1:br-data external:br-ex
data-port: br-data:eth1 br-ex:eth2
neutron-api:
flat-network-providers: physnet1 external
Alternative configuration with two external networks, one for public instance addresses and one for floating IP addresses. Both networks are on the same physical network connection (but they might be on different VLANs, that is configured later using neutron net-create).
neutron-api:
neutron net-create --provider:network_type vlan \
--provider:segmentation_id 400 \
--provider:physical_network physnet1 --shared external
--provider:segmentation_id 401 \
--provider:physical_network physnet1 --shared --router:external=true \
floating
neutron router-gateway-set provider floating
This replaces the previous system of using ext-port, which always created a bridge called br-ex for external networks which was used implicitly by external router interfaces.
Note: If data-port is specified, the value of ext-port is ignored. This prevents misconfiguration of the charm. Aditionaly, in this scenario an error message is logged and the unit is marked as blocked in order to notify about the misconfiguration.
Deferred service events
Operational or maintenance procedures applied to a cloud often lead to the restarting of various OpenStack services and/or the calling of certain charm hooks. Although normal, such events can be undesirable due to the service interruptions they can cause.
The deferred service events feature provides the operator the choice of preventing these service restarts and hook calls from occurring, which can then be resolved at a more opportune time.
See the Deferred service events page in the OpenStack Charms Deployment Guide for an in-depth treatment of this feature.
Navigation
| Level | Path | Navlink |
| 1 | Home |
