netbox-k8s docs: Configure OIDC
Configure OIDC
The NetBox charm makes use of the oauth integration for OIDC. You can find more information in charmhub.
OIDC is configured in NetBox using the library python-social-core with the OIDC backend.
To configure it, you only need to integrate your OIDC provider with NetBox K8s:
juju integrate hydra netbox-k8s
For NetBox to work, you may need to customise some of the following configuration options:
  • oidc-scopes: OIDC scopes are used by an application during authentication to authorize access to a user’s details, like name and picture. It must include openid to be a valid OIDC.
  • oidc-redirect-path: The redirect URL used by the OIDC provider to redirect back to NetBox application after the authorization is done.
NetBox configuration options for OIDC can be configured like:
juju config netbox-k8s oidc-scopes="openid profile email" oidc-redirect-path="/oauth/complete/oidc/"
