Configure SAML
The NetBox charm makes use of the saml-integrator for SAML. You can find more information in charmhub.
SAML is configured in NetBox using the library python-social-core with the SAMLAuth backend.
To configure it, you need to know the entidy_id and metadata_url of your IdP provider.
entity_id must be a valid URI. It can be configured with the following commands:
juju deploy saml-integrator --channel latest/edge --config entity_id=<idp_entidy_id> --config metadata_url=<idp_metadata_url>
juju integrate saml-integrator netbox
For NetBox to work, you may need to customise some of the following configuration options:
saml-sp-entity-id: SAML SP entity id. This is mandatory, and should be a correct URL.saml-username: SAML attribute used for both the social uid and the username (name_id by default).saml-email: SAML attribute used for the email (optional).
NetBox configuration options for SAML can be configured like:
juju config netbox saml-sp-entity-id=<your_sp_entity_id_url> saml-username=<saml_attribute_for_uid_and_username>
