Hi
I am trying to deploy charmed kubernetes. vSphere datastore issue is solved but now I am facing possible name resolution issues.
I have homelab01.local as a subdomain hosted on my dns server 192.168.255.220.
DHCP range is configured with my dns server and name resolution works.
However I see deployment issue:
0 down pending focal Post “https://esxi.homelab01.local/nfc/5285bf92-8ce0-
9b89-76c3-a647e805c836/disk-0.vmdk”: dial tcp: lookup esxi.homelab01.local on 127.0.0.53:53: server m
isbehaving
1 down pending focal Post “https://esxi.homelab01.local/nfc/5294cd72-ea11-
6141-6e87-fd236df414a7/disk-0.vmdk”: dial tcp: lookup esxi.homelab01.local on 127.0.0.53:53: server m
isbehaving
2 down pending focal Post “https://esxi.homelab01.local/nfc/52bfc33a-924c-
ff21-b607-24252de120c6/disk-0.vmdk”: dial tcp: lookup esxi.homelab01.local on 127.0.0.53:53: server m
isbehaving
3 down juju-4f1711-3 focal poweredOn
4 down juju-4f1711-4 focal poweredOn
5 down pending focal cloning VM: 0.00%
6 down juju-4f1711-6 focal poweredOn
7 down pending focal cloning VM: 0.00%
8 down pending focal cloning VM: 0.00%
9 down juju-4f1711-9 focal poweredOn
I logged in into juju controller and I see following config:
ystemd-resolve --status
Global
DNSSEC NTA: 10.in-addr.arpa
16.172.in-addr.arpa
168.192.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 2 (ens192)
Current Scopes: DNS
LLMNR setting: yes
MulticastDNS setting: no
DNSSEC setting: no
DNSSEC supported: no
DNS Servers: 192.168.255.220
8.8.8.8
8.8.4.4
DNS Domain: kubelab01.local
I can ping dns server ubuntu@juju-7ac43d-0:/etc/netplan$ ping 192.168.255.220 PING 192.168.255.220 (192.168.255.220) 56(84) bytes of data. 64 bytes from 192.168.255.220: icmp_seq=1 ttl=63 time=0.490 ms
What might cause the error in this deployment? Is this really the name resolution issue or something else?
