Hi,
I’m trying to develop a charm that connects to a mysql-router subordinate that integrates to a mysql-innodb-cluster charm. This is my metadata.yaml file where I defined my required relations:
requires:
identity-service:
interface: keystone
database:
interface: mysql-shared
This is how I’m trying to access the information:
#!/usr/bin/env python3
"""Charm the service.
Refer to the following post for a quick-start guide that will help you
develop a new k8s charm using the Operator Framework:
https://discourse.charmhub.io/t/4208
import logging
import subprocess
from pathlib import Path
from ops_openstack.core import OSBaseCharm
from ops.framework import StoredState
from ops.main import main
from ops.model import (
ActiveStatus
from charmhelpers.core import templating
from charmhelpers.core.host import restart_on_change
from charmhelpers.contrib.openstack import templating as os_templating
from charms.openstack_libs.v0.keystone_requires import (
KeystoneRequires
from charms.openstack_libs.v0.gnocchi_requires import (
GnocchiRequires
from charms.openstack_libs.v0.rabbitmq_requires import (
RabbitMQRequires
from charms.data_platform_libs.v0.data_interfaces import (
DatabaseRequires
from charms.operator_libs_linux.v1.systemd import (
service_restart
logger = logging.getLogger(__name__)
class CloudkittyCharm(OSBaseCharm):
"""Charm the service."""
_stored = StoredState()
PACKAGES = [
'cloudkitty-api',
'cloudkitty-processor'
REQUIRED_RELATIONS = [
'database',
'identity-service',
'metric-service',
'amqp'
CONFIG_FILE_OWNER = 'cloudkitty'
CONFIG_FILE_GROUP = 'cloudkitty'
CONFIG_DIR = Path('/etc/cloudkitty')
CONFIG_FILE = 'cloudkitty.conf'
CONFIG_PATH = CONFIG_DIR / CONFIG_FILE
SERVICES = ['cloudkitty-api', 'cloudkitty-processor']
RESTART_MAP = {
str(CONFIG_PATH): SERVICES
release = 'yoga'
def __init__(self, framework):
super().__init__(framework)
super().register_status_check(self.status_check)
self._app_name = self.model.app.name
self._address = None
self._stored.is_started = True
self.identity_service = KeystoneRequires(
charm=self,
relation_name='identity-service',
service_endpoints=[{
'service_name': self._app_name,
'internal_url': self.service_url('internal'),
'public_url': self.service_url('public'),
'admin_url': self.service_url('public')
region=self.model.config['region']
self.metric_service = GnocchiRequires(
charm=self,
relation_name='metric-service'
self.rabbitmq = RabbitMQRequires(
charm=self,
relation_name='amqp',
username=self._app_name,
vhost=self._app_name,
self.database = DatabaseRequires(
charm=self,
relation_name='database',
database_name=self._app_name
self.framework.observe(self.on.config_changed,
self._on_config_changed)
self.framework.observe(self.identity_service.on.ready,
self._on_identity_service_ready)
self.framework.observe(self.metric_service.on.ready,
self._on_metric_service_ready)
self.framework.observe(self.database.on.database_created,
self._on_database_created)
self.framework.observe(self.rabbitmq.on.ready,
self._on_amqp_ready)
self.framework.observe(self.on.restart_services_action,
self._on_restart_services_action)
@property
def protocol(self):
return 'http'
@property
def host(self) -> str:
if self._address is None:
binding = self.model.get_binding('public')
self._address = binding.network.bind_address
return str(self._address)
@property
def port(self) -> int:
return 8889
def service_url(self, _) -> str:
return f'{self.protocol}://{self.host}:{self.port}'
def status_check(self):
return ActiveStatus()
@restart_on_change(RESTART_MAP)
def _render_config(self, _) -> str:
"""Render configuration
Render related services configuration into
cloudkitty configuration file
_template_loader = os_templating.get_loader(
'templates/',
self.release
_context = {
'options': self.model.config,
'identity_service': self.identity_service,
'metric_service': self.metric_service,
'databases': self.database.fetch_relation_data(),
'rabbitmq': self.rabbitmq,
return templating.render(
source=self.CONFIG_FILE,
target=self.CONFIG_PATH,
context=_context,
template_loader=_template_loader,
owner=self.CONFIG_FILE_OWNER,
group=self.CONFIG_FILE_GROUP,
perms=0o640
def _bootstrap_db(self):
"""Bootstrap Database
On this function we handle the execution of
the storage initialization and then dbsync upgrade.
If any of the command fails it will return a non-zero
value and unit falls into error state.
This method is only executed on the leader unit.
if not self.model.unit.is_leader():
logger.info('unit is not leader, skipping bootstrap db')
return
logger.info('starting cloudkitty db migration')
commands = [
['cloudkitty-storage-init'],
['cloudkitty-dbsync', 'upgrade']
for cmd in commands:
logger.info(f"executing {cmd} command")
subprocess.check_call(cmd)
def _on_config_changed(self, event):
""" Handle config changed event.
self._render_config(event)
self.update_status()
def _on_identity_service_ready(self, event):
""" Handle identity-service relation ready event.
def _on_metric_service_ready(self, event):
""" Handle metric-service relation ready event.
def _on_database_created(self, event):
""" Handle Database created event.
self._bootstrap_db()
def _on_amqp_ready(self, event):
""" Handle RabbitMQ relation ready event.
def _on_restart_services_action(self, event):
""" Restart cloudkitty services action.
event.log(f"restarting services {', '.join(self.SERVICES)}")
for service in self.SERVICES:
if service_restart(service):
event.fail(f"Failed to restart service: {service}")
if __name__ == "__main__":
main(CloudkittyCharm)
However, the mysql-router subordinate keeps complaining that
unit-cloudkitty-mysql-router-7: 22:54:33 ERROR unit.cloudkitty-mysql-router/7.juju-log Unable to find implementation for relation: requires of juju-info
and most importantly:
cloudkitty-mysql-router/6* waiting idle 172.16.42.74 'shared-db' incomplete, Waiting for proxied DB creation from cluster
I’m thinking maybe the OPS framework doesn’t support mysql-router as a subordinate yet? Can you guide me on what’s wrong?
