MySQL Router K8s Reference - Revision 96
MySQL Router K8s revision 96
March 22, 2024
Dear community, this is to inform you that new MySQL Router K8s is published in 8.0/stable charmhub channel for Kubernetes.
The features you can start using today:
Bugfixes included:
  • Bootstrap mysql-router with force option in #187
  • Fix upgrade compatibility check in #202
  • Retry if MySQL Server is unreachable in #190
What is inside the charms:
  • Charmed MySQL Router K8s ships MySQL Router “8.0.35-0ubuntu0.22.04.1”
  • CLI mysql-shell version is “8.0.35-0ubuntu0.22.04.1~ppa1”
  • The Prometheus mysql-router-exporter is “4.0.5-0ubuntu0.22.04.1~ppa1”
  • K8s charms based on our ROCK OCI (resource-revision 49, based on Ubuntu LTS “22.04” - ubuntu:22.04-based)
  • Principal charms supports the latest LTS series “22.04” only
Technical notes:
  • Upgrade (juju refresh) is possible from this revision 69+
  • Use this operator together with a modern operator “Charmed MySQL K8s”
How to reach us:
If you would like to chat with us about your use-cases or ideas, choose your way from the list.
Contribute to the project!
