Minor Upgrade
Example: MySQL Router 8.0.33 -> MySQL Router 8.0.34
(including simple charm revision bump: from revision 99 to revision 102)
We strongly recommend to NOT perform any other extraordinary operations on Charmed MySQL cluster and/or MySQL Router, while upgrading. As an examples, these may be (but not limited to) the following:
- Adding or removing units
- Creating or destroying new relations
- Changes in workload configuration
- Upgrading other connected/related/integrated applications simultaneously
The concurrency with other operations is not supported, and it can lead the cluster into inconsistent states.
NOTE: Make sure to have a Charmed MySQL backups of your data when running any type of upgrades.
TIP: The “MySQL Router” upgrade should follow first, before “Charmed MySQL” upgrade!!!
Minor upgrade steps
WIP…
