Optimal MySQL Router Setup
For optimal performance, it is recommended that MySQL Router is run alongside your application and that your application uses a Unix domain socket to connect to and execute queries against MySQL Router. The usage of a Unix domain socket here results in increased network performance due to the reduced network hops and in increased security due to the lack of exposed ports.
When your application implements the modern (preferred) interface in MySQL Router’s supported interfaces , the MySQL Router charm is deployed as a subordinate of your application charm and your application will be presented with a Unix domain socket, over the interface, to connect to MySQL Router.
Accessing MySQL Router outside of Juju
A known limitation of relating with MySQL Router (a subordinate charm) is that your application would need to be deployed as a Juju application. However, if your application exists outside of the Juju ecosystem, you can access MySQL Router externally with the Data Integrator charm.
Example setup
The steps below show you how to deploy and set up MySQL, MySQL Router, and Data Integrator for access outside of Juju.
First, deploy all the charms:
juju deploy mysql --channel 8.0/edge --trust
juju deploy data-integrator --config database-name=test_database
juju deploy mysql-router --channel dpe/edge
Feel free to change
test_databaseto your name of choice
Integrate:
mysqlwithmysql-routerdata-integratorwithmysql-router, since in this case we want to generate the credentials to access MySQL Router
juju integrate mysql mysql-router
juju integrate data-integrator mysql-router
The following is a sample output of the get-credentials action run on a data-integrator unit:
- task 2 on unit-data-integrator-0
Waiting for task 2...
mysql:
data: '{"database": "test_database", "external-node-connectivity": "true", "requested-secrets":
"[\"username\", \"password\", \"tls\", \"tls-ca\", \"uris\"]"}'
database: test_database
endpoints: 10.205.193.235:6446
password: mysupersecuredatabasepassword
read-only-endpoints: 10.205.193.235:6447
username: relation-9-8
ok: "True"
You can then connect to MySQL Router with the provided endpoints from your application that resides outside of Juju.
Using a Virtual IP to connect to MySQL Router
If the MySQL Router charm is related to the Data Integrator charm, it is possible for a user to configure MySQL Router to use a certain Virtual IP. This assumes that the user has somehow ensured that the Virtual IP resolves to the node on which the MySQL Router charm is deployed.
To configure the MySQL Router charm with a virtual IP, run
juju config mysql-router/0 vip=<your_virtual_ip>
Integrate with HACluster
Alternatively, you can integrate with the HACluster charm if you would like a Virtual IP that is generated and maintained for you.
HACluster is a collection of solutions by ClusterLabs designed to create and manage resources. The creation of resources like Virtual IPs is handled by Pacemaker, whereas the management of these resources is handled by Corosync.
Pacemaker will create and attach a Virtual IP to one of your Data Integrator nodes (that is related to MySQL Router), while Corosync will ensure automatic failover if the node with the Virtual IP faces connectivity or other issues. This setup requires at least 3 Data Integrator nodes, each related to both MySQL Router and HACluster.
Warning: The Virtual IP supplied to MySQL Router should be in the same subnet as the nodes on which the MySQL Router charm is running. Else, you may encounter unexpected behavior from the HACluster charm when it tries to create the Virtual IP.
Example setup
The steps below show you how to deploy and set up MySQL, MySQL Router, Data Integrator, and HACluster.
juju deploy -n 3 data-integrator --config database-name=test_database
juju deploy hacluster
Note that the
data-integratorrequires a minimum of 3 nodes for this HACluster setup to work
Configure the VIP on mysql-router. Please ensure that the VIP is in an accessible subnet:
juju config mysql-router vip=10.205.193.35
Then, integrate:
mysql-routerwithmysqlmysql-routerandhaclusterwithdata-integratormysql-routerwithhacluster
juju integrate mysql-router mysql
juju integrate data-integrator:juju-info hacluster:juju-info
juju integrate mysql-router hacluster
mysql:
endpoints: 10.205.193.35:6446
read-only-endpoints: 10.205.193.35:6447
username: relation-12_cf668cc3521149-9
ok: "True"
