Mysql-innodb-cluster: Cluster ... not yet created by leader
The error occurs when the OpenStack bundle is initially deployed.
All 3 units stuck. Workload: waiting Message: Cluster mysql-test-cluster not yet created by leader
I removed all 3 units and deployed the bundle again. The units were created and stucks again.
Any ideas what’s going wrong?
root@maas:~# juju run-action mysql-innodb-cluster/leader --wait cluster-status
unit-mysql-innodb-cluster-5: UnitId: mysql-innodb-cluster/5 id: “24” results: cluster-status: “null” status: completed timing: completed: 2021-07-01 16:49:37 +0000 UTC enqueued: 2021-07-01 16:49:36 +0000 UTC started: 2021-07-01 16:49:36 +0000 UTC
Bundle-Config
  mysql-innodb-cluster:
    charm: cs:mysql-innodb-cluster-8
    num_units: 3
    bindings:
      "": *oam-space
      cluster: *cluster-space
      shared-db: *internal-space
      db-router: *internal-space
    options:
      cluster-name: mysql-test-cluster
      innodb-buffer-pool-size: 8G
      innodb-io-capacity: 15000
      max-connections: 2000
      enable-binlogs: True
    to:
    - lxd:0
    - lxd:1
    - lxd:2
ubuntu@juju-02e4d2-1-lxd-19:~$ service mysql status
● mysql.service - MySQL Community Server Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2021-07-01 15:36:09 UTC; 49min ago Process: 11720 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS) Main PID: 11728 (mysqld) Status: “Server is operational” Tasks: 41 (limit: 314572) Memory: 994.3M CGroup: /system.slice/mysql.service └─11728 /usr/sbin/mysqld
Jul 01 15:36:08 juju-02e4d2-1-lxd-19 systemd[1]: Starting MySQL Community Server… Jul 01 15:36:09 juju-02e4d2-1-lxd-19 systemd[1]: Started MySQL Community Server.
juju debug-log --replay --include=mysql-innodb-cluster/5
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju Starting unit workers for "mysql-innodb-cluster/5"
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.apicaller [6c8aaf] "unit-mysql-innodb-cluster-5" successfully connected to "10.6.32.2:17070"
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.apicaller [6c8aaf] password changed for "unit-mysql-innodb-cluster-5"
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.apicaller [6c8aaf] "unit-mysql-innodb-cluster-5" successfully connected to "10.6.160.2:17070"
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.upgrader no waiter, upgrader is done
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.migrationminion migration phase is now: NONE
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.logger logger worker started
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.meterstatus skipped "meter-status-changed" hook (missing)
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.uniter unit "mysql-innodb-cluster/5" started
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.uniter resuming charm install
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.uniter.charm downloading cs:mysql-innodb-cluster-8 from API server
unit-mysql-innodb-cluster-5: 15:34:28 INFO juju.worker.uniter hooks are retried true
unit-mysql-innodb-cluster-5: 15:34:29 INFO juju.worker.uniter.storage initial storage attachments ready
unit-mysql-innodb-cluster-5: 15:34:29 INFO juju.worker.uniter found queued "install" hook
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.operation ran "install" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "mysql-innodb-cluster:certificates vault:certificates"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "mysql-innodb-cluster:certificates vault:certificates"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "cinder-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "cinder-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "aodh-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "aodh-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "octavia-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "octavia-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "neutron-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "neutron-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "mysql-innodb-cluster:coordinator"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "mysql-innodb-cluster:coordinator"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "vault-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "vault-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "mysql-innodb-cluster:cluster"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "mysql-innodb-cluster:cluster"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "glance-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "glance-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "barbican-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "barbican-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "placement-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "placement-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "gnocchi-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "gnocchi-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "keystone-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "keystone-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "dashboard-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "dashboard-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joining relation "nova-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:05 INFO juju.worker.uniter.relation joined relation "nova-mysql-router:db-router mysql-innodb-cluster:db-router"
unit-mysql-innodb-cluster-5: 15:36:06 INFO juju.worker.uniter.operation skipped "db-router-relation-created" hook (missing)
unit-mysql-innodb-cluster-5: 15:36:06 INFO juju.worker.uniter.operation skipped "coordinator-relation-created" hook (missing)
unit-mysql-innodb-cluster-5: 15:36:06 INFO juju.worker.uniter.operation skipped "cluster-relation-created" hook (missing)
unit-mysql-innodb-cluster-5: 15:36:06 INFO juju.worker.uniter.operation skipped "certificates-relation-created" hook (missing)
unit-mysql-innodb-cluster-5: 15:36:07 INFO juju.worker.uniter found queued "leader-elected" hook
unit-mysql-innodb-cluster-5: 15:36:09 INFO juju.worker.uniter.operation ran "leader-elected" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:13 INFO juju.worker.uniter.operation ran "config-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:13 INFO juju.worker.uniter found queued "start" hook
unit-mysql-innodb-cluster-5: 15:36:17 INFO juju.worker.uniter.operation ran "start" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:21 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:24 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:28 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:31 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:35 INFO juju.worker.uniter.operation ran "coordinator-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:38 INFO juju.worker.uniter.operation ran "coordinator-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:42 INFO juju.worker.uniter.operation ran "certificates-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:46 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:49 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:53 INFO juju.worker.uniter.operation ran "coordinator-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:57 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:36:59 INFO juju.worker.uniter.operation ran "coordinator-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:03 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:07 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:11 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:14 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:18 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:22 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:26 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:29 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:33 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:37 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:41 INFO juju.worker.uniter.operation ran "cluster-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:45 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:49 INFO juju.worker.uniter.operation ran "cluster-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:53 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:37:57 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:01 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:05 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:09 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:13 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:16 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:20 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:24 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:29 INFO juju.worker.uniter.operation ran "certificates-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:32 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:37 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:41 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:45 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:49 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:53 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:38:57 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:01 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:05 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:09 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:13 INFO juju.worker.uniter.operation ran "cluster-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:17 INFO juju.worker.uniter.operation ran "cluster-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:22 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:26 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:30 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:34 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:38 INFO juju.worker.uniter.operation ran "certificates-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:43 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:47 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:51 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:39:56 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:00 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:04 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:08 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:13 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:17 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:22 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:26 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:31 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:35 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:39 INFO juju.worker.uniter.operation ran "cluster-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:44 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:48 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:52 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:40:57 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:01 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:05 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:10 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:14 INFO juju.worker.uniter.operation ran "certificates-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:18 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:23 INFO juju.worker.uniter.operation ran "certificates-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:27 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:31 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:36 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:40 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:45 INFO juju.worker.uniter.operation ran "certificates-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:49 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:53 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:41:57 INFO juju.worker.uniter.operation ran "db-router-relation-joined" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:42:02 INFO juju.worker.uniter.operation ran "db-router-relation-changed" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:45:41 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:50:31 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 15:55:17 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:00:40 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:05:34 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:09:58 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:15:29 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:21:08 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:25:30 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:30:57 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:36:26 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:40:41 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:46:14 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:51:18 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
unit-mysql-innodb-cluster-5: 16:55:53 INFO juju.worker.uniter.operation ran "update-status" hook (via explicit, bespoke hook script)
