Hi,
When the server goes down the mysql-innodb-cluster showing inaccessible
openstack juju-controller maassrv/default 2.9.14 unsupported 11:54:56+05:30
App Version Status Scale Charm Store Channel Rev OS Message
mysql-innodb-cluster 8.0.26 blocked 3 mysql-innodb-cluster charmhub stable 11 ubuntu Cluster is inaccessible from this instance. Please check logs for details.
mysql-innodb-cluster/0* active idle 0/lxd/0 192.168.0.9 Unit is ready: Mode: R/W, Cluster is NOT tolerant to any failures. 2 members are not active.
mysql-innodb-cluster/1 blocked idle 1/lxd/0 192.168.0.235 Cluster is inaccessible from this instance. Please check logs for details.
mysql-innodb-cluster/2 blocked idle 2/lxd/0 192.168.0.236 Cluster is inaccessible from this instance. Please check logs for details.
0 started 192.168.0.5 HP-01 focal default Deployed
0/lxd/0 started 192.168.0.9 juju-e45ffe-0-lxd-0 focal default Container started
1 started 192.168.0.6 HP-02 focal default Deployed
1/lxd/0 started 192.168.0.235 juju-e45ffe-1-lxd-0 focal default Container started
2 started 192.168.0.7 HP-03 focal default Deployed
2/lxd/0 started 192.168.0.236 juju-e45ffe-2-lxd-0 focal default Container started
