Hey there,
after rebooting my single node OpenStack I cannot get the cluster back up. Many containers never come back up. It’s obviously because of the mysql instance not being able to boot.
It’s trying to recover as it seems but the mysqld_safe exists unexpectedly. When starting up a docker.io/library/mysql container with that very hostpath volume, it works totally fine. How can this be resolved. It seems like there is not recover option like in the old charmed mysql operator…
unit-mysql-0: 21:27:32 ERROR unit.mysql/0.juju-log Uncaught exception while in charm code:
File "/var/lib/juju/agents/unit-mysql-0/charm/./src/charm.py", line 724, in <module>
main(MySQLOperatorCharm)
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/main.py", line 441, in main
_emit_charm_event(charm, dispatcher.event_name)
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/main.py", line 149, in _emit_charm_event
event_to_emit.emit(*args, **kwargs)
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/framework.py", line 344, in emit
framework._emit(event)
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/framework.py", line 841, in _emit
self._reemit(event_path)
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/framework.py", line 930, in _reemit
custom_handler(event)
File "/var/lib/juju/agents/unit-mysql-0/charm/./src/charm.py", line 525, in _on_mysql_pebble_ready
self._reconcile_pebble_layer(container)
File "/var/lib/juju/agents/unit-mysql-0/charm/./src/charm.py", line 364, in _reconcile_pebble_layer
container.replan()
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/model.py", line 1984, in replan
self._pebble.replan_services()
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/pebble.py", line 1686, in replan_services
return self._services_action('replan', [], timeout, delay)
File "/var/lib/juju/agents/unit-mysql-0/charm/venv/ops/pebble.py", line 1767, in _services_action
raise ChangeError(change.err, change)
ops.pebble.ChangeError: cannot perform the following tasks:
- Start service "mysqld_safe" (cannot start service: exited quickly with code 0)
----- Logs from task 0 -----
2023-11-16T20:27:32Z INFO Most recent service output:
2023-11-16T20:27:32.460327Z mysqld_safe Logging to '/var/log/mysql/error.log'.
2023-11-16T20:27:32.474107Z mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
2023-11-16T20:27:32.707547Z mysqld_safe mysqld from pid file /var/lib/mysql/mysql-0.pid ended
2023-11-16T20:27:32Z ERROR cannot start service: exited quickly with code 0
