Hello everyone, When I am trying to create a Pipeline or an Experiment or a Run (that has already run successfully in the past), I receive the following error: The kubeflow is installed using charmed-kubeflow, on a microk8s cluster
Failed to retry run Failed to retry run: f8b571bd-132d-4d2b-8739-efa2f00f3a36 with error: “{“error”:“InternalServerError: Failed to update the database entry.: InternalServerError: Failed to update run f8b571bd-132d-4d2b-8739-efa2f00f3a36. error: ‘Error 1290: The MySQL server is running with the --read-only option so it cannot execute this statement’: Error 1290: The MySQL server is running with the --read-only option so it cannot execute this statement”,“code”:13,“message”:“InternalServerError: Failed to update the database entry.: InternalServerError: Failed to update run f8b571bd-132d-4d2b-8739-efa2f00f3a36. error: ‘Error 1290: The MySQL server is running with the --read-only option so it cannot execute this statement’: Error 1290: The MySQL server is running with the --read-only option so it cannot execute this statement”,“details”:[{”@type":" type .googleapis.com/api. Error",“error_message”:“Internal Server Error”,“error_details”:“InternalServerError: Failed to update the database entry.: InternalServerError: Failed to update run f8b571bd-132d-4d2b-8739-efa2f00f3a36. error: ‘Error 1290: The MySQL server is running with the --read-only option so it cannot execute this statement’: Error 1290: The MySQL server is running with the --read-only option so it cannot execute this statement”}]}" ```
The juju status command shows that kserve-controller is in error state (hook failed :install)
The logs of the kserve-controller juju unit are represented below:
2025-02-25T13:36:21.061Z [container-agent] 2025-02-25 13:36:21 WARNING install Generating RSA private key, 2048 bit long modulus (2 primes) 2025-02-25T13:36:21.116Z [container-agent] 2025-02-25 13:36:21 WARNING install …+++++ 2025-02-25T13:36:21.120Z [container-agent] 2025-02-25 13:36:21 WARNING install …+++++ 2025-02-25T13:36:21.121Z [container-agent] 2025-02-25 13:36:21 WARNING install e is 65537 (0x010001) 2025-02-25T13:36:21.130Z [container-agent] 2025-02-25 13:36:21 WARNING install Generating RSA private key, 2048 bit long modulus (2 primes) 2025-02-25T13:36:21.149Z [container-agent] 2025-02-25 13:36:21 WARNING install …+++++ 2025-02-25T13:36:21.286Z [container-agent] 2025-02-25 13:36:21 WARNING install …+++++ 2025-02-25T13:36:21.286Z [container-agent] 2025-02-25 13:36:21 WARNING install e is 65537 (0x010001) 2025-02-25T13:36:21.316Z [container-agent] 2025-02-25 13:36:21 WARNING install Signature ok 2025-02-25T13:36:21.316Z [container-agent] 2025-02-25 13:36:21 WARNING install subject=C = GB, ST = Canonical, L = Canonical, O = Canonical, OU = Canonical, CN = 127.0.0.1 2025-02-25T13:36:21.316Z [container-agent] 2025-02-25 13:36:21 WARNING install Getting CA Private Key 2025-02-25T13:36:21.388Z [container-agent] 2025-02-25 13:36:21 INFO juju-log Rendering manifests 2025-02-25T13:36:22.928Z [pebble] Check “readiness” failure 10 (threshold 3): received non-20x status code 418 2025-02-25T13:36:24.345Z [container-agent] 2025-02-25 13:36:24 INFO juju-log HTTP Request: PATCH https:// 10.152.183.1 /apis/apiextensions.k8s.io/v1/customresourcedefinitions/clusterservingruntimes.serving.kserve.io?fieldManager=lightkube “HTTP/1.1 409 Conflict” 2025-02-25T13:36:24.395Z [container-agent] 2025-02-25 13:36:24 ERROR juju-log Apply failed with 2 conflicts: conflicts with “kubectl-client-side-apply” using apiextensions.k8s.io/v1: 2025-02-25T13:36:24.395Z [container-agent] - .metadata.annotations.controller-gen.kubebuilder.io/version 2025-02-25T13:36:24.395Z [container-agent] - .spec.versions 2025-02-25T13:36:24.407Z [container-agent] 2025-02-25 13:36:24 ERROR juju-log Uncaught exception while in charm code: 2025-02-25T13:36:24.407Z [container-agent] Traceback (most recent call last): 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/lightkube/core/generic_client.py”, line 188, in raise_for_status 2025-02-25T13:36:24.407Z [container-agent] resp.raise_for_status() 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/httpx/_models.py”, line 749, in raise_for_status 2025-02-25T13:36:24.407Z [container-agent] raise HTTPStatusError(message, request=request, response=self) 2025-02-25T13:36:24.407Z [container-agent] httpx.HTTPStatusError: Client error ‘409 Conflict’ for url ‘[https:// 10.152.183.1/apis/apiextensions.k8s.io/v1/customresourcedefinitions/clusterservingruntimes.serving.kserve.io?fieldManager=lightkube’]( https:// 10.152.183.1/apis/apiextensions.k8s.io/v1/customresourcedefinitions/clusterservingruntimes.serving.kserve.io?fieldManager=lightkube%27) 2025-02-25T13:36:24.407Z [container-agent] For more information check: https:// httpstatuses,com /409 2025-02-25T13:36:24.407Z [container-agent] 2025-02-25T13:36:24.407Z [container-agent] During handling of the above exception, another exception occurred: 2025-02-25T13:36:24.407Z [container-agent] 2025-02-25T13:36:24.407Z [container-agent] Traceback (most recent call last): 2025-02-25T13:36:24.407Z [container-agent] File “./src/charm.py”, line 553, in 2025-02-25T13:36:24.407Z [container-agent] main(KServeControllerCharm) 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/ops/main.py”, line 439, in main 2025-02-25T13:36:24.407Z [container-agent] framework.reemit() 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/ops/framework.py”, line 843, in reemit 2025-02-25T13:36:24.407Z [container-agent] self._reemit() 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/ops/framework.py”, line 922, in _reemit 2025-02-25T13:36:24.407Z [container-agent] custom_handler(event) 2025-02-25T13:36:24.407Z [container-agent] File “./src/charm.py”, line 340, in _on_install 2025-02-25T13:36:24.407Z [container-agent] self.k8s_resource_handler.apply() 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/charmed_kubeflow_chisme/kubernetes/_kubernetes_resource_handler.py”, line 348, in apply 2025-02-25T13:36:24.407Z [container-agent] raise e 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/charmed_kubeflow_chisme/kubernetes/_kubernetes_resource_handler.py”, line 333, in apply 2025-02-25T13:36:24.407Z [container-agent] apply_many(client=self.lightkube_client, objs=resources, force=force) 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/charmed_kubeflow_chisme/lightkube/batch/_many.py”, line 64, in apply_many 2025-02-25T13:36:24.407Z [container-agent] returns[i] = client.apply( 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/lightkube/core/client.py”, line 457, in apply 2025-02-25T13:36:24.407Z [container-agent] return self.patch(type(obj), name, obj, namespace=namespace, 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/lightkube/core/client.py”, line 325, in patch 2025-02-25T13:36:24.407Z [container-agent] return self._client.request(“patch”, res=res, name=name, namespace=namespace, obj=obj, 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/lightkube/core/generic_client.py”, line 245, in request 2025-02-25T13:36:24.407Z [container-agent] return self.handle_response(method, resp, br) 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/lightkube/core/generic_client.py”, line 196, in handle_response 2025-02-25T13:36:24.407Z [container-agent] self.raise_for_status(resp) 2025-02-25T13:36:24.407Z [container-agent] File “/var/lib/juju/agents/unit-kserve-controller-0/charm/venv/lightkube/core/generic_client.py”, line 190, in raise_for_status 2025-02-25T13:36:24.407Z [container-agent] raise transform_exception(e) 2025-02-25T13:36:24.407Z [container-agent] lightkube.core.exceptions.ApiError: Apply failed with 2 conflicts: conflicts with “kubectl-client-side-apply” using apiextensions.k8s.io/v1: 2025-02-25T13:36:24.407Z [container-agent] - .metadata.annotations.controller-gen.kubebuilder.io/version 2025-02-25T13:36:24.407Z [container-agent] - .spec.versions 2025-02-25T13:36:24.682Z [container-agent] 2025-02-25 13:36:24 ERROR juju.worker.uniter.operation runhook.go:153 hook “install” (via hook dispatching script: dispatch) failed: exit status 1 2025-02-25T13:36:24.683Z [container-agent] 2025-02-25 13:36:24 INFO juju.worker.uniter resolver.go:155 awaiting error resolution for “install” hook 2025-02-25T13:36:32.928Z [pebble] Check “readiness” failure 11 (threshold 3): received non-20x status code 418 2025-02-25T13:36:42.925Z [pebble] Check “readiness” failure 12 (threshold 3): received non-20x status code 418 2025-02-25T13:36:52.927Z [pebble] Check “readiness” failure 13 (threshold 3): received non-20x status code 418 2025-02-25T13:37:02.928Z [pebble] Check “readiness” failure 14 (threshold 3): received non-20x status code 418
I do not have previous experience with both juju and kubeflow. What may cause this issue?
Thank you in advance
