Overview
This is a tutorial in connection with the multi-user framework of Juju. See Working with multiple users for background information.
This tutorial will give an overview of how Juju can be used with one person assuming the role of a system administrator and a second person acting as the Juju administrator.
The system administrator creates the controller, creates users, and grants user permissions whereby the operator is responsible for creating models and installing software.
The following topics will be covered:
- Controller creation and the initial controller administrator
- User creation and controller registration
- User login, logout, and password changing
- User model creation
- User charm deployment
Duration: 03:00
Besides resulting in a new controller the bootstrap command sets up a Juju user called âadminâ with controller permissions of âsuperuserâ. This is the initial controller administrator.
Here weâll add credentials and then create a GCE-based controller:
juju add-credential google -f credentials-administrator.yaml
juju bootstrap google gce
In the above the credentials file contains a single credential for the âgoogleâ cloud, allowing it to become the default credential in the subsequent bootstrap command.
Inspecting the controllerâs users with the users command allows us to confirm the above information:
juju users
Example output:
Controller: gce
Name Display name Access Date created Last connection
admin* admin superuser 2 minutes ago just now
Note that the new administrator does not have a password per se. Create one now:
juju change-user-password
Duration: 03:00
Let the administrator now create a regular user called âtomâ:
juju add-user tom
The output of juju add-user includes a string (token) to send to the new user. This will enable that administrator to register the controller to their own Juju client.
Sample output:
User "tom" added
Please send this command to tom:
juju register MGcTA3RvbTA5ExQzNS4yMzcuMTY1LjI[...]
"tom" has not been granted access to any models. You can use "juju grant" to grant access.
The client host must be able to contact the controller host on TCP port 17070 in order for controller registration to succeed. This is the case for any client-controller communication.
Registration is done with the register command. On a separate host, then:
Example output:
Enter a new password: ******
Confirm password: ******
Enter a name for this controller [gce]:
Initial password successfully set for tom.
Welcome, tom. You are now logged into "gce".
There are no models available. You can add models with
"juju add-model", or you can ask an administrator or owner
of a model to grant access to that model with "juju grant".
Duration: 01:00
A newly-created user is granted controller access of âloginâ out of the box (implicitly: juju grant -c gce tom login). So besides logging in, the user cannot do much else.
Registration implies a controller login (as can be seen by the previous commandâs messaging). To log out, use the logout command:
juju logout
A login session also expires after a fixed amount of time (24 hours).
To log back in, use the login command with the username as argument. Provide the password that was set up during registration:
juju login -u tom
Supply a controller name (-c gce) if there is more than one controller registered with the client.
Change the userâs password with the change-user-password command:
User model creation
Duration: 02:00
In order for users to be able to add models, the admin user must grant âadd-modelâ access to them:
juju grant tom add-model
Yet before the grantee is able to create a model with the new permissions, a credential needs to be added to Juju.
On the userâs host, add a credential and then juju add-model will succeed:
juju add-credential google -f credentials-tom.yaml
juju add-model gce-model-1
In the above the credentials file (credentials-tom.yaml) contains a single credential for the âgoogleâ cloud, allowing it to become the default credential in the subsequent add-model command.
User model SSH access
Duration: 01:00
The operator user can now connect, using Jujuâs ssh command, to any machine that may get created within their new model. This is standard Juju behaviour that the model creator always enjoys. Note, however, that the SSH keys necessary for this to work are found within the client systemâs filesystem at ~/.local/share/juju/ssh/juju_id_rsa.pub (and ~/.ssh/id_rsa.pub if it existed at the time of model creation).
Verify SSH access now on the operator host:
juju add-machine
juju ssh 0
Above we assume the machine that was added got assigned an ID of â0â (the default for the first machine in a model).
Duration: 01:00
The operator user can now deploy charms as normal. See Deploying applications for help.
Thatâs the end of this tutorial!
