Hello!
In an attempt to clean up my controller from this: https://discourse.jujucharms.com/t/model-destroy-failure-manual-clean-up/1320
and to learn more, I have decided to bring up a new controller and migrate what I need from the old one.
Basically, create new controller - migrate a working CDK model - remove the old controller which has broken stuff in the db.
Yesterday, I followed the instructions at https://discourse.jujucharms.com/t/migrating-models/1152
Since I ran the migrate command, nothing seems to happen.
status:
current: busy
message: 'migrating: starting'
since: 16 hours ago
migration: starting
migration-start: 16 hours ago
Where can I find out more?
The debug-log of the controller contains a repeated, single message that I also had before the migration, and afaik did not prevent juju from working:
WARNING juju.worker.peergrouper multiple usable addresses found
run "juju config juju-ha-space=<name>" to set a space for Mongo peer communication preserving member with unchanged address [...]
Am I missing something? Is there a way to cancel the migration?
Thanks
