Normally, when changes are made to an application, the changes are applied immediately to all its units. Examples of such changes include:
- upgrading a charm
- attaching a resource to an application
- setting configuration options for an application
Model “branches” enable application changes to be applied on a per-unit basis. Differences between units of the main branch and unaffected units is intended as transitional. The transition allows for you to inspect and validate the progress of upgrades as the upgrade is rolled out. The procedure is completed by having the changes applied to all application units. This operational mode is known as model generations.
The primary use case of model generations is to support blue-green deployments. Rather than upgrading every unit at the same time, units are upgraded in small batches. , are m for a large infrastructure that consists of a great number of application units. It is an optional conservative approach for managing infrastructure changes.
In-progress feature:
To use model branches, you need to enable the feature flag: branches, e.g.:
export JUJU_DEV_FEATURE_FLAGS=branches
Development of model branches is not complete.
Terminology
branch
track
commit
generations
Overview
- Adding a branch to the model
- Setting units to track a branch
- Changing application configuration for a branch
- Validating that units are tracked
- Committing a branch
- Aborting a branch
juju add-branch <name-of-branch>
$ juju add-branch test
Created branch "test" and set active
This leads to creating a new branch “test”, which units can track.
Charm configuration applied to that branch can be applied to the units following it.
Setting Units to track a branch
First of all, we need to have an application and some units as a setup.
In this example we are using mediawiki.
$ juju deploy mediawiki
Located charm "cs:mediawiki-19".
Deploying charm "cs:mediawiki-19".
$ juju add-unit mediawiki
With the application and its units set up, we can ask the units to track a specific branch.
juju track [options] <branch name> <entities>
Examples:
juju track test mediawiki/0
Specific units can be set to track a branch by supplying multiple unit IDs.
All units of an application can be set to track a branch by passing an
application name. Units can only track one branch at a time.
Tracking the specific /0 unit:
$ juju track test mediawiki/0
juju status can be used to verify which unit is tracking which branch.
The #<number> under Unit inidicates the branch a Unit is following.
The * indicates under Branch the current active branch.
Following above leads to below example which shows the following information:
- The current active branch is:
testand has areferencecalled#1. -
mediawiki/0followstestbecause it has a ref to#1. -
mediawiki/1does not followtest.
$ juju status
default awsspace2 aws/eu-central-1 2.8-beta1.1 unsupported 10:26:11+01:00
Branch Ref Created Created By
test* #1 9 minutes ago admin
mediawiki 1.19.14 blocked 2 mediawiki jujucharms 19 ubuntu
mediawiki/0* #1 blocked idle 1 18.196.255.248 Database required
mediawiki/1 blocked idle 3 3.122.95.32 Database required
0 started 172.31.3.4 i-0e34b325342fd34a6 bionic eu-central-1a running
1 started 18.196.255.248 i-0afa54d075bd82ac8 trusty eu-central-1a running
Changing application config on a branch
Only one branch can be active at a time to apply changes.
The juju branch command displays the current active branch:
$ juju branch
Active branch is "test"
To make a change under the branch test, use juju config. This change will change the use_suffix parameter to true from true.
$ juju config mediawiki use_suffix=false
Verify that the change is set to false
false
switch to branch master, the default branch, again:
$ juju branch master
Active branch set to "master"
verify that the change has not been applied yet
true
Committing the branch
Now we can test the changes on unit /0 and realized the changes are working as expected.
With this, we can apply the branch test to master.
$ juju commit test
Branch "test" committed; model is now at generation 1
To have a changelog and verify what changes we did we have the following commands:
juju commits and juju show-commit
juju commits
shows the timeline of changes to the model that occurred through branching.
information consists of:
- the commit number
- user who committed the branch
- when the branch was committed
- the branch name
$ juju commits
Commit Committed at Committed by Branch name
1 26 seconds ago admin test
juju show-commit
Show-commit shows the committed branches to the model.
Details displayed include:
- user who created the branch
- when the branch was created
- configuration made under the branch for each application
- a summary of how many units are tracking the branch
❯ juju show-commit 1
branch:
test:
applications:
- application: mediawiki
units:
tracking:
- mediawiki/0
- mediawiki/1
config:
use_suffix: false
committed-at: 18 Feb 2020 11:14:13+01:00
committed-by: admin
created: 18 Feb 2020 10:16:41+01:00
created-by: admin
6. Aborting a branch
The advantage of using branches is that one can test the changes and either commit or abort them.
The above example under 5. committed the branch.
But let’s assume that the change we added is not working as expected.
With this, we can instead to commit, abort the branch.
Note that we can only abort branches when no units are tracking it.
Following the above example, we need to remove the tracking unit:
Branch bla is already in use and a unit is tracking it.
❯ juju abort test
ERROR branch is in progress. Either reset values on tracking units or remove them to abort.
Therefore the current way to remove it is to do either one of the following:
- EITHER: reset the changes to the application and commit the branch:
juju config mediawiki --reset use_suffix
juju commit test
- OR: remove the unit tracking the branch
❯ juju remove-unit mediawiki/0
removing unit mediawiki/0
❯ juju abort bla
Aborting all changes in "bla" and closing branch.
