When I ran microstack.init again, there were NO Microstack service errors reported in system logs.
The full transcript is:
$ sudo microstack.init
[sudo] password for doug:
Do you want to setup clustering? (yes/no) [default=no] > yes
2020-10-07 17:33:03,441 - microstack_init - INFO - Configuring clustering …
What is this machines’ role? (control/compute) > compute
Please enter a cluster password >
Please re-enter password >
Please enter the ip address of the control node [default=192.168.1.141] > 192.168.1.141
Please enter the ip address of this node [default=192.168.1.142] > 192.168.1.142
2020-10-07 17:33:59,009 - microstack_init - INFO - I am a compute node.
File “/snap/microstack/210/bin/microstack_join”, line 11, in
load_entry_point(‘microstack-cluster==0.0.1’, ‘console_scripts’, ‘microstack_join’)()
File “/snap/microstack/210/lib/python3.8/site-packages/cluster/client.py”, line 26, in join
raise Exception(‘Failed to get info from control node: {}’.format(
Exception: Failed to get info from control node: <bound method Response.json of <Response [500]>>
File “/snap/microstack/210/bin/microstack_init”, line 11, in
load_entry_point(‘microstack-init==0.0.1’, ‘console_scripts’, ‘microstack_init’)()
File “/snap/microstack/210/lib/python3.8/site-packages/init/main.py”, line 55, in wrapper
return func(*args, **kwargs)
File “/snap/microstack/210/lib/python3.8/site-packages/init/main.py”, line 171, in init
question.ask()
File “/snap/microstack/210/lib/python3.8/site-packages/init/questions/question.py”, line 210, in ask
self.yes(awr)
File “/snap/microstack/210/lib/python3.8/site-packages/init/questions/init.py”, line 84, in yes
check_output(‘microstack_join’)
File “/snap/microstack/210/lib/python3.8/site-packages/init/shell.py”, line 80, in check_output
return subprocess.check_output(args, env=env,
File “/usr/lib/python3.8/subprocess.py”, line 411, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/lib/python3.8/subprocess.py”, line 512, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘(‘microstack_join’,)’ returned non-zero exit status 1.
