Hi, this is my first using microstack ussuri release (devmode). Is it possible to add new storage, volume group to the microstack ? which is doable in standard Openstack. I cannot find the Cinder configuration file (cinder.conf) where i can configure new volume group to be detected by openstack.
Hi Azizul,
Thank you for the question! Currently, MicroStack only supports local storage. I believe that other storage systems are on the roadmap, but are not yet implemented.
Thank you for the information.
