MicroK8s is a snap that makes it easy to install Kubernetes on a single machine. As well as Kubernetes itself, MicroK8s includes a large suite of prepackaged addons.
With only a few commands, three or more machines running MicroK8s can be combined in a high-availability MicroK8s cluster. (A two-machine cluster is also possible, but it won’t be HA.)
That’s still a lot of typing and deploying VMs or machines, so I decided to write a charm to make the process easier. Now, with a suitable Juju controller and machine provider, those commands above become simply:
juju deploy -n3 --constraints 'cpus=2 mem=4G' cs:~pjdc/microk8s
(4G is a reasonable minimum for MicroK8s to deploy and form a cluster. Depending on what you decide to run in k8s, you may well need more!)
When the deployment completes, you’ll note that the cluster has been formed, and you can see every Kubernetes node from each microk8s unit.
$ juju exec --application microk8s -- 'microk8s status | grep -A2 high-availability:'
- return-code: 0
stdout: |
high-availability: yes
datastore master nodes: 10.15.254.233:19001 10.15.254.234:19001 10.15.254.235:19001
datastore standby nodes: none
unit: microk8s/0
- return-code: 0
stdout: |
unit: microk8s/2
- return-code: 0
stdout: |
unit: microk8s/1
$ juju exec --application microk8s -- microk8s kubectl get nodes
- return-code: 0
stdout: |
NAME STATUS ROLES AGE VERSION
juju-439239-microk8s-1 Ready <none> 6m3s v1.19.3-34+a56971609ff35a
juju-439239-microk8s-0 Ready <none> 8m3s v1.19.3-34+a56971609ff35a
juju-439239-microk8s-2 Ready <none> 4m51s v1.19.3-34+a56971609ff35a
unit: microk8s/0
- return-code: 0
stdout: |
unit: microk8s/1
- return-code: 0
stdout: |
unit: microk8s/2
$ _
Now you can add the cluster to your Juju controller (in this example, named microk8s):
juju expose microk8s
juju ssh microk8s/0 microk8s config | \
juju add-k8s microk8s --cluster-name=microk8s-cluster --controller=microk8s --skip-storage
and deploy k8s Juju charms:
$ juju deploy cs:~mattermost-charmers/mattermost
Located charm "cs:~mattermost-charmers/mattermost-9".
Deploying charm "cs:~mattermost-charmers/mattermost-9".
$ juju status
mattermost microk8s microk8s/default 2.8.3 unsupported 01:18:53Z
App Version Status Scale Charm Store Rev OS Address Notes
mattermost waiting 1 mattermost jujucharms 9 kubernetes Waiting for database relation
mattermost/0* waiting idle Waiting for database relation
$ _
The charm has a couple of additional features to support unusual or restricted environments.
Kubernetes requires nodes to be able to find each other by name. If necessary, you can use juju config microk8s manage_etc_hosts=true to tell the charm to handle this.
For microk8s to deploy successfully, it needs to be able to fetch some OCI images from the Internet. If your environment requires this access to be via a proxy, use juju config containerd_env to tell the charm how to configure this.
If access to external DNS servers is restricted, then CoreDNS will not be able to look up any names, since it defaults to Google Public DNS, and your applications may not work. Using juju config coredns_config, change the forwarders option to a value that will work for you.
The charm’s source code is currently hosted in a personal repository on Launchpad, but as work continues on the charm and if others are interested to contribute it may move to a team namespace. Please give it a try and let me know what you think.
