MFA Authentication
Hi,
I’m using a charmed Openstack with Ubuntu 20.04 and Yoga as the Openstack version.
I’m trying to use MFA to enable TOTP authentication and password-based authentication, but I realized that TOTP is not enabled by default on Horizon (Dashboard). Is there any way to tell the dashboard charm that I’m going to override a few files to enable MFA on the dashboard and that the files I modify should not be changed? How would you approach this change? I just don’t my modifications to be overridden when we update the Openstack version.
Thank you so much for any help or guidance you guys can provide.
Greetings,
C.
