Metrics
The details of the metrics exposed by hardware-observer for PowerEdge RAID Controllers are as follows:
| Metric Name | Description | Labels |
| poweredgeraid_controllers | number of controllers | hostname |
| poweredgeraid_virtual_drive | number of virtual drives | controller_id |
| perccli_command_success | Indicates the if command is successful or not | controller_id |
| perccli_command_ctrl_success | Indicates the if command for each controller is successful or not | controller_id |
| poweredgeraid_virtual_drive_info | Indicates the state of virtual drive | controller_id, device_group, virtual_drive_id, state, cache_policy |
| poweredgeraid_physical_device_info | Shows the information about the physical device | controller_id, enclosure_id, slot_id, size, media_type, state |
Alerts
The details of the alets that are provided by hardware-observer for PowerEdge RAID Controllers are as follows:
| Alert Rule Name | Description | Alert Condition | Severity |
| PerccliCommandFailed | Failed to run perccli or controller not available. | perccli_command_success == 1 | critical |
| PowerEdgeRAIDControllerNotFound | PowerEdge RAID controller not found. | poweredgeraid_controllers == 1 | warning |
| PowerEdgeRAIDControllerSuccess | PowerEdge RAID controller command not successful. | perccli_command_ctrl_success == 0 | critical |
| PowerEdgeRAIDVirtualDriveNotOptimal | PowerEdge RAID virtual drives are not in optimal state. | poweredgeraid_virtual_info{state != “Optl”} == 1 | warning |
