How to contribute
For any problems with this charm, please report bugs here.
The code for this charm can be downloaded as follows:
git clone https://git.launchpad.net/charm-k8s-mattermost
To run tests, simply run make test from within the charm code directory.
Local Deployment
To deploy a test setup locally using microk8s, with PostgreSQL deployed into the same model:
sudo snap install juju-wait --classic
sudo snap install microk8s --classic
sudo snap alias microk8s.kubectl kubectl
sudo snap install charmcraft
make -C charm-k8s-mattermost mattermost.charm
microk8s.reset # Warning! Clean slate!
microk8s.enable dns dashboard registry storage
microk8s.status --wait-ready
microk8s.config | juju add-k8s myk8s --client
juju bootstrap myk8s
juju add-model mattermost-test
juju deploy cs:~postgresql-charmers/postgresql-k8s postgresql
juju deploy ./charm-k8s-mattermost/mattermost.charm mattermost
juju wait
juju status
juju relate mattermost postgresql:db
