I have created k8s cluster using juju charms. After deployment, when I check node details with command “kubectl get no” , only worker nodes are showing but master nodes are not showing. Is there any issues with deployment or it is the issue with juju charms.
@getrati99 could you please provide the commands that you used to deploy the cluster?
Assuming this is a double up of https://discourse.charmhub.io/t/kubectl-get-no-command-is-not-showing-master-nodes/3060/5
