Hi All, I tried mapping vlan tagged to public interface. But there are some issuse which i can’t ping to instance. Could you help me this? Here is my deploy config: variables: openstack-origin: &openstack-origin distro data-port: &data-port br-ex:bond0 worker-multiplier: &worker-multiplier 0.25 osd-devices: &osd-devices /dev/sdb /dev/sdc /dev/sdd /dev/sde expected-osd-count: &expected-osd-count 3 expected-mon-count: &expected-mon-count 3
Neutron API config : vlan-ranges: source: user type: string value: physnet1:100:2000 I tried to create vlan using horizon dashboard: name: vlan 171 project: admin provider: vlan physical network: physnet1 segment: 171
ovn-chassis: ovn-bridge-mappings: physnet1:br-ex bridge-interface-mappings: br-ex:bond0
ubuntu@e17u27:~$ sudo ovs-vsctl show 955697ed-ede1-4e54-adf0-e3106a01015e Manager “ptcp:6640:127.0.0.1” is_connected: true Bridge br-ex fail_mode: standalone datapath_type: system Port br-ex Interface br-ex type: internal Port bond0 Interface bond0 type: system Bridge br-int Controller “tcp:127.0.0.1:6633” is_connected: true fail_mode: secure datapath_type: system Port ovn-e17u35-0 Interface ovn-e17u35-0 type: geneve options: {csum=“true”, key=flow, remote_ip=“172.16.10.24”} Port ovn-e17u29-0 Interface ovn-e17u29-0 type: geneve options: {csum=“true”, key=flow, remote_ip=“172.16.10.22”} Port ovn-e17u32-0 Interface ovn-e17u32-0 type: geneve options: {csum=“true”, key=flow, remote_ip=“172.16.10.23”} Port ovn-e17u28-0 Interface ovn-e17u28-0 type: geneve options: {csum=“true”, key=flow, remote_ip=“172.16.10.21”} Port br-int Interface br-int type: internal ovs_version: “2.13.0” ubuntu@e17u27:~$
But after create i can’t ping or take ARP from switch. Sure switch has right trunking config. Could you help me suggestions for this case?
