Table of Contents
- Initial situation
- Analysing the charm through SOLID Principles
- Making it more SOLID
- Final notes on the improvements brought about by these changes
When I am asked what a Charm is, I like to explain it synthetically as:
“It is software that manages the life cycle of other software. It can do this thanks to Juju which is its orchestrator.”
It is obviously a simplification of the real definition:
A charm is software that wraps an application and that contains all of the instructions necessary for deploying, configuring, operating an application on any cloud using Juju.
A charm generally contains the operations (charm) code and the information on where to get the application itself (the workload). […]
Charms include deterministic logic that specifies what happens when specific events occur. Events can be triggered by an administrator (e.g. through the CLI), by other charms or the external environment.
But as a Charm author the term charm
not only refers to the package that can be installed running juju deploy my-charm
, it also refers to the file (src/charm.py
) in which we place the class
that represents the charm itself and the entry point of the charm execution.
A common mistake that Software Engineers make when we start writing charms is to confuse the real definition of charm which refers to the software package, with the src/charm.py
file. This way we start writing all the logic in that file. Although the charm will work well anyway, it will then be more complex to maintain, understand and extend it.
Would it be possible to improve the readability, maintainability while decoupling the code? Well, the answer is YES!
So, let’s tray to make our charms more SOLID
Initial situation
Some time ago I discovered snips.sh a really cool SSH-powered pastebin with a human-friendly TUI and web UI, and I decided to write a charm for it. I use it as a toy project and it was never the idea to make it production-ready, but who knows
Let’s start by taking a look of the src/charm.py
file:
import logging
import secrets
import string
from typing import Dict
from ops import PebbleReadyEvent
from ops.charm import CharmBase
from ops.main import main
from ops.model import (
ActiveStatus,
BlockedStatus,
MaintenanceStatus,
SecretNotFoundError,
from ops.pebble import ChangeError, Layer
# Log messages can be retrieved using juju debug-log
logger = logging.getLogger(__name__)
CONTAINER_NAME = "snips"
HTTP_PORT = 8080
SSH_PORT = 2222
LAYER_NAME = CONTAINER_NAME
SERVICE_NAME = CONTAINER_NAME
class SnipsK8SOperatorCharm(CharmBase):
"""Charm the service."""
def __init__(self, *args):
super().__init__(*args)
self._container = self.unit.get_container(CONTAINER_NAME)
self.framework.observe(self.on.snips_pebble_ready, self._on_snips_pebble_ready)
self.framework.observe(self.on.config_changed, self._on_config_changed)
self.framework.observe(self.on.update_status, self._on_update_status)
def _on_snips_pebble_ready(self, _: PebbleReadyEvent):
self._common_exit_hook()
def _on_config_changed(self, _):
def _on_update_status(self, _):
def _common_exit_hook(self) -> None:
"""Event processing hook that is common to all events to ensure idempotency."""
if not self._container.can_connect():
self.unit.status = MaintenanceStatus("Waiting for pod startup to complete")
return
# Update pebble layer
if not self._update_layer():
self.unit.status = BlockedStatus("Failed to update pebble layer. Check juju debug-log")
return
self.unit.status = ActiveStatus()
def _update_layer(self) -> bool:
"""Update service layer.
Returns:
True if anything changed; False otherwise
overlay = self.pebble_layer
plan = self._container.get_plan()
if SERVICE_NAME not in plan.services or overlay.services != plan.services:
self._container.add_layer(LAYER_NAME, overlay, combine=True)
try:
self._container.replan()
return True
except ChangeError as e:
logger.error(
"Failed to replan; pebble plan: %s; %s",
self._container.get_plan().to_dict(),
str(e),
return False
return True
@property
def _hmac_key(self) -> str:
try:
secret = self.model.get_secret(label="hmac-key")
except SecretNotFoundError:
secret = self.app.add_secret({"hmac-key": self._generate_hmac_key()}, label="hmac-key")
return secret.get_content()["hmac-key"]
def _generate_hmac_key(self) -> str:
"""Generate a random 24 character symmetric key used to sign URLs."""
chars = string.ascii_letters + string.digits
return "".join(secrets.choice(chars) for _ in range(24))
@property
def pebble_layer(self) -> Layer:
"""Pebble layer for the snips service."""
return Layer(
"summary": "snips layer",
"description": "pebble config layer for snips",
"services": {
"snips": {
"override": "replace",
"summary": "snips",
"command": "/usr/bin/snips.sh",
"startup": "enabled",
"environment": self._env_vars,
@property
def _env_vars(self) -> Dict:
env_vars = {
"SNIPS_DEBUG": True,
"SNIPS_HMACKEY": self._hmac_key,
return env_vars
if __name__ == "__main__": # pragma: nocover
main(SnipsK8SOperatorCharm)
This is an easy to read, short file with only 141 lines of code. It couldn’t be better, could it! Well no, actually that code could be much better, let’s analyse it!
Single Responsibility Principle (SRP)
The Single Responsibility Principle states that a module, a class, or even a method should have a single, well-defined responsibility. It should do just one thing and have only one reason to change.
If we carefully analyse the SnipsK8SOperatorCharm
class we notice that it has multiple responsibilities:
- Handle events (
snips_pebble_ready
,config_changed
andupdate_status
). - Manage secret keys (
_hmac_key
,_generate_hmac_key
). - Configure and generate Pebble layer (
pebble_layer
,_env_vars
So the problem here is crystal clear : The class is taking on too many responsibilities, which means it has multiple reasons to change.
When we think about a charm, and specially the class
that represents it in src/charm.py
file, what would be that one thing the class should be responsible for?
One answer to this question could be:
Probably the only thing a charm class should do is to observe (and react to) events. All other tasks can be performed by ad-hoc classes.
Open/Closed Principle (OCP)
If we now analyse the class from the OCP point of view, we can find some issues:
- The
_common_exit_hook
method contains specific logic to check if it is possible to connect to the container and update the Pebble plan. - The
pebble_layer
property is directly implemented inside the charm, with no possibility to easily extend it for different configurations or services.
The problem here is that if we want to extend the behaviour of the charm or change the Pebble layer, we will need to modify the existing code instead of extending it.
Liskov Substitution Principle (LSP):
We do not have an explicit violation in this code because SnipsK8SOperatorCharm
is not used in a polymorphic context and there is no subtype substitution involved.
Interface Segregation Principle (ISP):
Well, we don’t seem to violate this principle either!
Dependency Inversion Principle (DIP):
depends directly on concrete implementations such as secrets.choice
, and ops.pebble.Layer
. We do not have abstractions to handle secret keys or Pebble configurations.
This makes it difficult to replace these dependencies.
My strategy here is to split the code in src/charm.py
into 5 different modules with the following classes. You can check the code in this branch.
charm
: Observes and react to the events.
components_init
ComponentsInitialiser
: Initialise the components needed bySnipsK8SOperatorCharm
snips
Snips
: Configure the Pebble layer for the snips workload
secret_manager
SecretManager
: Manages the secret key.
tasks
Task
: Just an interface for the tasks that the charm will executeValidateCanConnectTask
: Validates if it is possible to connect to the workload containerUpdatePebbleLayerTask
: Updates Pebble layerTasksFactory
: A class factory that generates a list of the tasks that need to be executed by the charm.
Now, let’s take a look a those modules!
charm
import logging
from typing import List
from ops import main
from ops.model import ActiveStatus
from components_init import ComponentsInitialiser
from snips import CONTAINER_NAME
from tasks import Task, TasksFactory
"""Snips charm class."""
def __init__(self, framework):
super().__init__(framework)
initialiser = ComponentsInitialiser(self, CONTAINER_NAME)
self._container, self._snips = initialiser.initialise_components()
self._tasks: List[Task] = TasksFactory(self).tasks
self._observe_events()
def _observe_events(self):
self.framework.observe(self.on.snips_pebble_ready, self._reconcile)
self.framework.observe(self.on.update_status, self._reconcile)
self.framework.observe(self.on.config_changed, self._reconcile)
def _reconcile(self, _) -> None:
for task in self._tasks:
if not task.execute():
return
Woow! now we have 21 lines class!! Much easier to understand than the previous version!
components_init
from secret_manager import SecretManager
from snips import Snips
class ComponentsInitialiser:
"""Initialise the components for the charm."""
def __init__(self, charm, container_name):
self.charm = charm
self.container_name = container_name
def initialise_components(self):
container = self.charm.unit.get_container(self.container_name)
secret_manager = SecretManager(self.charm)
snips = Snips(container, secret_manager.hmac_key)
return container, snips
snips
import logging
from ops import Container
HTTP_PORT = 8080
SSH_PORT = 2222
class Snips:
"""Snips workload container facade."""
def __init__(self, container: Container, hmac_key: str):
self._container = container
self._hmac_key = hmac_key
@property
return Layer(
"services": {
"snips": {
"summary": "snips",
@property
env_vars = {
return env_vars
def update_layer(self) -> bool:
Returns:
try:
return True
logger.error(
str(e),
return False
return True
secret_manager
import secrets
import string
from ops.model import SecretNotFoundError
class SecretManager:
"""Secret Manager class."""
def __init__(self, charm):
self.charm = charm
@property
def hmac_key(self) -> str:
"""Retrieve or create hmac-key."""
try:
secret = self.charm.model.get_secret(label="hmac-key")
secret = self.charm.app.add_secret(
tasks
import logging
from typing import List, Protocol
BlockedStatus,
MaintenanceStatus,
TASK_EXECUTED = "Task '%s' executed."
TASK_FAILED = "Task '%s' failed: %s"
class Task(Protocol):
"""Task interface."""
def execute(self) -> bool:
"""Task execution.
Return True if the execution is successful otherwise False.
class TasksFactory:
"""TaskFactory class."""
self._charm = charm
@property
def tasks(self) -> List[Task]:
"""List of tasks."""
return [
ValidateCanConnectTask(self, self._charm._container),
UpdatePebbleLayerTask(self, self._charm._snips),
class ValidateCanConnectTask:
"""Validate Can Connect task class."""
def __init__(self, charm, container):
self._class_name = __class__.__name__
self.charm = charm
"""Task execution."""
msg = "Waiting for pod startup to complete"
self.charm.unit.status = MaintenanceStatus(msg)
logger.debug(TASK_FAILED, self._class_name, msg)
return False
logger.debug(TASK_EXECUTED, self._class_name)
return True
class UpdatePebbleLayerTask:
"""Update Pebble Layer task class."""
def __init__(self, charm, snips):
self._charm = charm
self._snips = snips
if not self._snips.update_layer():
msg = "Unable to update Pebble layer. Check juju debug-log"
self._charm.unit.status = BlockedStatus(msg)
return False
return True
Improvement: The initialisation of components and creation of tasks has been delegated:
encapsulates the logic for initialising components (_container
,_snips
).TasksFactory
is responsible for task creation (Task
), removing this responsibility from the charm.
Outcome: The
class now has a single responsibility: observe (and react to) events. This improves cohesion.
- Improvement: The task creation logic is abstracted in
TasksFactory
, allowing new tasks to be added without modifying the charm. - Outcome: The charm is open to extension (e.g., adding new tasks or components) without requiring changes to its base code.
- Improvement:
- The charm uses
TasksFactory
andComponentsInitialiser
, which encapsulate details of underlying dependencies such as the container and Pebble. - This ensures that the charm only interacts with interfaces relevant to its purpose (event and task management).
- The charm uses
- Outcome: Exposure to unnecessary external dependencies is reduced.
- Improvement:
- The initialisation of components and tasks is delegated to
andTasksFactory
, which abstract concrete dependencies. - This ensures that the charm depends on abstractions (such as lists of tasks and initialised containers) instead of concrete details.
- Outcome: The code is more modular and easier to maintain or test.
I believe this approach demonstrates that applying SOLID principles to charms results in clean, modular, and maintainable codebases. While the initial charm was functional, this refactor ensures that it is sustainable and scalable in the long term. Making charms more SOLID Making charms more SOLID
