Here’s a quick tutorial to get you comfortable with the MAAS Operator Charm.
- First, create some environment variables to facilitate this tutorial:
# LaunchPad ID
export LP_ID="my-lp-id"
export MAAS_REGION_CHARM=./maas-region-charm/maas-region_ubuntu-22.04-amd64.charm
- Install the base packages:
sudo snap install juju
sudo snap install lxd
sudo snap install charmcraft --classic
- Initialize Juju:
# The actual command doesn't matter, just run juju once
juju whoami
- Create a managed LXD network as a control plane:
lxc network create jujulab
lxc network edit jujulab <<EOF
description: "Juju lab network"
type: bridge
config:
dns.domain: juju-lab
ipv4.address: 10.70.0.1/24
ipv4.dhcp: "true"
ipv4.dhcp.ranges: 10.70.0.65-10.70.0.126
ipv4.nat: "true"
ipv6.address: none
EOF
- Integrate this lab network with the host’s DNS service:
resolvectl dns jujulab 10.70.0.1
resolvectl domain jujulab '~juju-lab'
- Make this integration persistent (optional, but highly recommended):
cat <<EOF | sudo tee /etc/systemd/system/lxd-dns-net-juju.service
[Unit]
Description=LXD per-link DNS configuration for jujulab
BindsTo=sys-subsystem-net-devices-jujulab.device
After=sys-subsystem-net-devices-jujulab.device
[Service]
Type=oneshot
ExecStart=/usr/bin/resolvectl dns jujulab 10.70.0.1
ExecStart=/usr/bin/resolvectl domain jujulab '~juju-lab'
ExecStopPost=/usr/bin/resolvectl revert jujulab
RemainAfterExit=yes
[Install]
WantedBy=sys-subsystem-net-devices-jujulab.device
EOF
sudo systemctl daemon-reload
sudo systemctl enable --now lxd-dns-net-juju
- Create an unmanaged network for Devices-Under-Test (DUT):
lxc network create jujudata
lxc network edit jujudata <<EOF
description: "Juju test network"
type: bridge
config:
dns.domain: jujudata
ipv4.address: 10.70.1.1/24
ipv4.dhcp: "false"
ipv4.nat: "false"
ipv6.address: none
EOF
Create a LXD project to isolate the lab:
We don’t need a Separate set of images for the project, so we disable it to save some disk space and download time.
lxc project create juju-lab -c features.images=false
lxc project switch juju-lab
- Create a profile for Juju controllers:
lxc profile create juju-host
lxc profile edit juju-host <<EOF
description: Juju host
config:
limits.cpu: 2
limits.memory: 4GB
user.user-data: |
#cloud-config
ssh_authorized_keys:
- $(cat ${HOME}/.ssh/id_rsa.pub | cut -d' ' -f1-2)
- $(cat ${HOME}/.local/share/juju/ssh/juju_id_rsa.pub | cut -d' ' -f1-2)
devices:
eth0:
type: nic
network: jujulab
eth1:
type: nic
network: jujudata
root:
path: /
pool: default
type: disk
EOF
- Create a profile for devices under test:
lxc profile create juju-dut
lxc profile edit juju-dut <<EOF
description: Juju lab DUT
devices:
eth0:
type: nic
network: jujudata
root:
path: /
pool: default
type: disk
EOF
- Create a few VMs:
for h in $(seq 1 3); do \
lxc launch ubuntu:jammy "m$h" --vm -p juju-host;\
done;\
sleep 5;\
lxc exec "m$h" -- cloud-init status --wait;\
ssh-keyscan -H "m$h.juju-lab" >> ~/.ssh/known_hosts;\
done
- Bootstrap the Juju controller:
cat >| maas-bootstrap.yaml <<EOF
clouds:
maas-bootstrap:
type: manual
endpoint: ubuntu@m1.juju-lab
regions:
default: {}
EOF
juju add-cloud maas-bootstrap ./maas-bootstrap.yaml
juju bootstrap maas-bootstrap maas-controller
juju add-machine -m controller ssh:ubuntu@m2.juju-lab
juju add-machine -m controller ssh:ubuntu@m3.juju-lab
juju enable-ha -n 3 --to 1,2
juju controllers --refresh
- Deploy a PostgreSQL DB using the charm:
juju deploy -m controller postgresql --channel 14/stable --series jammy --to 0
juju add-unit -m controller postgresql -n 2 --to 1,2
- Deploy HAProxy using the charm:
juju deploy -m controller haproxy --series jammy --to 0
juju add-unit -m controller haproxy -n 2 --to 1,2
- Deploy a MAAS region controller in Region+Rack mode using the charm:
juju deploy -m controller ${MAAS_REGION_CHARM} --to 0
juju config maas-region enable_rack_mode=true
juju status --watch 10s # wait for it to initialize
- Instruct Juju to consume offers:
juju integrate -m controller maas-region postgresql
juju integrate -m controller maas-region:ingress-tcp haproxy:haproxy-route-tcp
juju status --watch 10s # wait for it to settle
- Enable TLS
juju integrate -m controller maas-region:ingress-tcp-tls haproxy:haproxy-route-tcp
juju config -m controller maas-region ssl-cert-content $(cat certificate.cert)
juju config -m controller maas-region ssl-key-content $(cat certificate.key)
juju config -m controller maas-region ssl-cacert-content $(cat ca.cert) # Needed if the certificate is self-signed
- Create a MAAS admin user:
juju run -m controller maas-region/leader create-admin username=maas password=maas email=maas@example.com ssh-import=lp:${LP_ID}
- Get the MAAS URL, so you can access the MAAS instance:
juju run -m controller maas-region/leader get-api-endpoint
That’s all there is to it! Now you can explore your lab MAAS instance, created with the MAAS Operator Charm.
