Hey guys I have a question about whether I should do a MAAS installation for each Cloud I intend to use. Or I can have just one installation of MAAS and create, for example, 3 MAAS clouds: cloud prod-maas, dev-maas, test-maas. Can you help me? Thank you.
I believe the typical practice would be to use separate clouds based on the listed purposes, but the experts are on the MAAS Discourse at https://discourse.maas.io/.
Thank you @manadart!
