Contributing to loki-operator
Overview
This documents explains the processes and practices recommended for contributing enhancements to the Loki charm.
- Generally, before developing enhancements to this charm, you should consider opening an issue explaining your use case.
- If you would like to chat with us about your use-cases or proposed
implementation, you can reach us at
Canonical Mattermost public channel
or Discourse.
The primary author of this charm is available on the Mattermost channel as
@jose-masson. - It is strongly recommended that prior to engaging in any enhancements to this charm you familiarise your self with Juju.
- Familiarising yourself with the Charmed Operator Framework. library will help you a lot when working on PRs.
- All enhancements require review before being merged. Besides the
code quality and test coverage, the review will also take into
account the resulting user experience for Juju administrators using
this charm. Please help us out in having easier reviews by rebasing
onto the
mainbranch, avoid merge commits and enjoy a linear Git history.
Setup
A typical setup using snaps, for deployments to a microk8s cluster can be done using the following commands
sudo snap install microk8s --classic
microk8s.enable dns storage
juju bootstrap microk8s microk8s
juju create-storage-pool operator-storage kubernetes storage-class=microk8s-hostpath
Developing
Create and activate a virtualenv with the development requirements:
virtualenv -p python3 venv
source venv/bin/activate
pip install -r requirements.txt
Later on, upgrade packages as needed
pip install --upgrade -r requirements.txt
Testing
All tests can be executed by running tox without arguments.
To run individual test environments:
tox -e prettify # update your code according to linting rules
tox -e lint # check your code complies to linting rules
tox -e static # run static analysis
tox -e unit # run unit tests
Unit tests are implemented using the Operator Framework test harness.
Build
Install the charmcraft tool and build the charm in this git repository:
charmcraft pack
Code Overview
The core implementation of this charm is represented by the LokiOperatorCharm class.
LokiOperatorCharm responds to the following events:
loki_pebble_ready: Here we set up pebble layer and start the servicerelation_joinedIn this event (Provided by the objectLokiPushApiProvider) we set theloki_push_api(http://{self.unit_ip}:{self.charm.port}/loki/api/v1/push) so it can be used by a Consumer charm that uses theLokiPushApiConsumerobject.
Both clases LokiPushApiProvider and LokiPushApiConsumer are provided by the Loki library
Design Choices
This Loki charm does not support (yet) the distributed deployment, only the standalone one.
