Tutorial: Get started
Here’s how to get started with using the charm-local-users application.
Firstly, create a configuration file as shown below:
$ cat config-local-users.yaml
local-users:
group: mygroup
users: |
alice;Alice;ssh-rsa ABC alice@desktop
bob;Bob;ssh-rsa XYZ bob@laptop
Deploy any principal charm application of your choice, e.g. Ubuntu
juju deploy ubuntu
Deploy the charm-local-users application providing the path to the configuration file you created earlier:
juju deploy --config config-local-users.yaml local-users
Relate to the principal charm application.
juju relate local-users ubuntu
The charm can also be configured after deployment.
For example, to remove bob’s account, create an updated user list file user.lst that doesn’t
include Bob’s account anymore and simply update the config:
$ cat user.lst
Now provide this config to the charm.
juju config local-users users=@user.lst
The charm will enter a blocked state if you try to add a user account that already exists but
isn’t a member of the managed group. If you’re sure that you want to add the pre-existing account
to the managed group anyway, making it a charm managed account from now, you can run:
juju config local-users allow-existing-users=true
Home directories of removed users will be backed up in the location specified in the backup-path config option before being removed.
