Configuration > Model configuration > List of model configuration keys
See also: Model, How to configure a model
agent-metadata-urlagent-streamagent-versionapt-ftp-proxyapt-http-proxyapt-https-proxyapt-mirrorapt-no-proxyauthorized-keysautomatically-retry-hooksbackup-dircharmhub-urlcloudinit-userdatacontainer-image-metadata-urlcontainer-image-streamcontainer-inherit-propertiescontainer-networking-methoddefault-basedefault-spacedevelopmentdisable-network-managementdisable-telemetryegress-subnetsenable-os-refresh-updateenable-os-upgradeextra-infofan-configfirewall-modeftp-proxyhttp-proxyhttps-proxyignore-machine-addressesimage-metadata-urlimage-streamjuju-ftp-proxyjuju-http-proxyjuju-https-proxyjuju-no-proxylogforward-enabledlogging-configlogging-outputlxd-snap-channelmax-action-results-agemax-action-results-sizemax-status-history-agemax-status-history-sizemodenamenet-bond-reconfigure-delayno-proxynum-container-provision-workersnum-provision-workersprovisioner-harvest-modeproxy-sshresource-tagssaas-ingress-allowsecret-backendsnap-http-proxysnap-https-proxysnap-store-assertionssnap-store-proxysnap-store-proxy-urlssh-allowssl-hostname-verificationstorage-default-block-sourcestorage-default-filesystem-sourcesyslog-ca-certsyslog-client-certsyslog-client-keysyslog-hosttest-modetransmit-vendor-metricstypeupdate-status-hook-intervaluuid
agent-metadata-url
URL of private stream.
Type: string
agent-stream
Version of Juju to use for deploy/upgrades.
Type: string
agent-version
Note: This value is set by Juju.
The desired Juju agent version to use.
Type: string
Note: This value cannot be changed after model creation.
apt-ftp-proxy
The APT FTP proxy for the model.
Type: string
apt-http-proxy
The APT HTTP proxy for the model.
Type: string
apt-https-proxy
The APT HTTPS proxy for the model.
Type: string
apt-mirror
The APT mirror for the model.
Type: string
apt-no-proxy
List of domain addresses not to be proxied for APT (comma-separated).
Type: string
authorized-keys
Any authorized SSH public keys for the model, as found in a ~/.ssh/authorized_keys file.
Type: string
Determines whether the uniter should automatically retry failed hooks.
Type: bool
backup-dir
Directory used to store the backup working directory.
Type: string
charmhub-url
The url for CharmHub API calls.
Type: string
cloudinit-userdata
Cloud-init user-data (in yaml format) to be added to userdata for new machines created in this model.
Type: string
The URL at which the metadata used to locate container OS image ids is located.
Type: string
The simplestreams stream used to identify which image ids to search when starting a container.
Type: string
List of properties to be copied from the host machine to new containers created in this model (comma-separated).
Type: string
Method of container networking setup - one of fan, provider, local.
Type: string
default-base
The default base image to use for deploying charms, will act like --base when deploying charms.
Type: string
default-space
The default network space used for application endpoints in this model.
Type: string
development
Whether the model is in development mode.
Type: bool
Whether the provider should control networks (on MAAS models, set to true for MAAS to control networks.
Type: bool
disable-telemetry
Disable telemetry reporting of model information.
Type: bool
egress-subnets
Source address(es) for traffic originating from this model.
Type: string
Whether newly provisioned instances should run their respective OS’s update capability.
Type: bool
enable-os-upgrade
Whether newly provisioned instances should run their respective OS’s upgrade capability.
Type: bool
extra-info
Arbitrary user specified string data that is stored against the model.
Type: string
fan-config
Configuration for fan networking for this model.
Type: string
firewall-mode
The mode to use for network firewalling.
‘instance’ requests the use of an individual firewall per instance.
‘global’ uses a single firewall for all instances (access for a network port is enabled to one instance if any instance requires that port).
‘none’ requests that no firewalling should be performed inside the model. It’s useful for clouds without support for either global or per instance security groups.
Type: string
Valid values: instance, global, none
ftp-proxy
The FTP proxy value to configure on instances, in the FTP_PROXY environment variable.
Type: string
http-proxy
The HTTP proxy value to configure on instances, in the HTTP_PROXY environment variable.
Type: string
https-proxy
The HTTPS proxy value to configure on instances, in the HTTPS_PROXY environment variable.
Type: string
Whether the machine worker should discover machine addresses on startup.
Type: bool
image-metadata-url
The URL at which the metadata used to locate OS image ids is located.
Type: string
image-stream
The simplestreams stream used to identify which image ids to search when starting an instance.
Type: string
juju-ftp-proxy
The FTP proxy value to pass to charms in the JUJU_CHARM_FTP_PROXY environment variable.
Type: string
juju-http-proxy
The HTTP proxy value to pass to charms in the JUJU_CHARM_HTTP_PROXY environment variable.
Type: string
juju-https-proxy
The HTTPS proxy value to pass to charms in the JUJU_CHARM_HTTPS_PROXY environment variable.
Type: string
juju-no-proxy
List of domain addresses not to be proxied (comma-separated), may contain CIDRs. Passed to charms in the JUJU_CHARM_NO_PROXY environment variable.
Type: string
logforward-enabled
Whether syslog forwarding is enabled.
Type: bool
logging-config
The configuration string to use when configuring Juju agent logging (see http://godoc.org/github.com/juju/loggo#ParseConfigurationString for details).
Type: string
logging-output
The logging output destination: database and/or syslog. (default “”).
Type: string
lxd-snap-channel
The channel to use when installing LXD from a snap (cosmic and later).
Type: string
The maximum age for action entries before they are pruned, in human-readable time format.
Type: string
The maximum size for the action collection, in human-readable memory format.
Type: string
The maximum age for status history entries before they are pruned, in human-readable time format.
Type: string
The maximum size for the status history collection, in human-readable memory format.
Type: string
mode
Mode is a comma-separated list which sets the mode the model should run in. So far only one is implemented
- If ‘requires-prompts’ is present, clients will ask for confirmation before removing potentially valuable resources. (default “”).
Type: string
name
The name of the current model.
Type: string
The amount of time in seconds to sleep between ifdown and ifup when bridging.
Type: int
no-proxy
List of domain addresses not to be proxied (comma-separated).
Type: string
The number of container provisioning workers to use per machine.
Type: int
The number of provisioning workers to use per model.
Type: int
What to do with unknown machines (default destroyed).
Type: string
Valid values: all, none, unknown, destroyed
proxy-ssh
Whether SSH commands should be proxied through the API server.
Type: bool
resource-tags
resource tags.
Type: attrs
saas-ingress-allow
Application-offer ingress allowlist is a comma-separated list of CIDRs specifying what ingress can be applied to offers in this model.
Type: string
secret-backend
The name of the secret store backend. (default “auto”).
Type: string
snap-http-proxy
The HTTP proxy value to for installing snaps.
Type: string
snap-https-proxy
The HTTPS proxy value to for installing snaps.
Type: string
The assertions for the defined snap store proxy.
Type: string
snap-store-proxy
The snap store proxy for installing snaps.
Type: string
The URL for the defined snap store proxy.
Type: string
ssh-allow
SSH allowlist is a comma-separated list of CIDRs from which machines in this model will accept connections to the SSH service. Currently only the aws & openstack providers support ssh-allow.
Type: string
Whether SSL hostname verification is enabled (default true).
Type: bool
The default block storage source for the model.
Type: string
The default filesystem storage source for the model.
Type: string
syslog-ca-cert
The certificate of the CA that signed the syslog server certificate, in PEM format.
Type: string
syslog-client-cert
The syslog client certificate in PEM format.
Type: string
syslog-client-key
The syslog client key in PEM format.
Type: string
syslog-host
The hostname:port of the syslog server.
Type: string
test-mode
Whether the model is intended for testing. If true, accessing the charm store does not affect statistical data of the store. (default false).
Type: bool
Determines whether metrics declared by charms deployed into this model are sent for anonymized aggregate analytics.
Type: bool
type
Type of model, e.g. local, ec2.
Type: string
How often to run the charm update-status hook, in human-readable time format (default 5m, range 1-60m).
Type: string
uuid
The UUID of the model.
Type: string
