We are trying to connect libjuju to a named controller and stumbling a bit along the way.
Is there a way to feed libjuju the information it needs to connect to a named controller outside of having it use the .yaml files in ~/.local/share/juju?
I currently don’t think this is possible in the current setup. Although you can pass the information to connect() method on the Controller, I believe you’ll run into other issues where the code relies/reads the information directly from the system.
I think doing the following might be the way forward:
This is definitely a gap in libjuju, and w/ the Juju api in general. I’d like to find a spot on the roadmap to fix this, but it hasn’t won out over competing priorities yet.
