landscape-client
Description
Landscape client is the daemon for Landscape server. This subordinate charm is intended to be used to register a machine against a running Landscape server. This charm uses the Ops framework
See the full Landscape documentation for more details.
Links
Usage
The minimal example to get started with Landscape SaaS
juju deploy landscape-client --config account-name=foo-bar
juju deploy ubuntu --series jammy
juju relate landscape-client ubuntu
To install using a PPA
--config ppa=ppa:landscape/self-hosted-beta
To connect to a Landscape Self-Hosted instance
juju deploy landscape-client \
--config computer-title=helloworld \
--config account-name=standalone \
--config url=https://mydomain.com/message-system \
--config ping-url=http://mydomain.com/ping \
However, when registering the client against a server with a custom or not well known
CA, we need to use the ssl-public-key option. To insert the certificate
contents into the charm config directly, encode it in base64 using the following syntax:
--config ssl-public-key=base64:<base64_encoded_certificate>
For example:
--config ssl-public-key=base64:LS0tLS1CRUdJTiBDRVJUSUZJQ0FURS0tLS4HY5RHZ6VWxUcDYwcjFNRmw1bG16M2I5a2dJeTVJeUYyUURCNnhXeEFMYXoKUGJwVCtnZ2NvYTN5Ci0tLS0tRU5EIENFUlRJRklDQVRFLS0tLS0=
If the certificate is already present in the client machine, then use the filepath:
--config ssl-public-key=/path/to/ca.cert
Upgrading
It is recommended to use the PPA.
juju config landscape-client ppa=ppa:landscape/self-hosted-beta
The charm upgrade action can be run as shown where landscape-client/0 is the desired unit.
For juju 3.0 and above, run:
juju run landscape-client/0 upgrade
For versions before juju 3.0, use run-action instead of run:
juju run-action landscape-client/0 upgrade
Re-registering
The charm will register the client once. Subsequent config-changed events will restart the service. If you want to register again, run:
juju run landscape-client/0 register
If you’re using a version before juju 3.0, use run-action instead of run.
Relations
Since this is a subordinate charm, a relation is required. (Breaking the relation via remove-relation will disable the client.)
In the following example the Ubuntu Charm is used.
This is accomplished using the juju-info interface. For more information, see Juju’s reference material on implicit integrations.
Source Code
The code for this updated version of the charm is in https://github.com/canonical/landscape-client-charm
Development
Make your code modifications and ensure that the options bundle.yaml are correct. Then
make build
To run linting and tests, cd into the top level directory and
sudo apt install tox
tox
To run an individual test:
tox tests/unit/test_charm.py::TestCharm::test_ssl_cert
The following commands may also be helpful:
juju status --watch 1s
juju debug-log --include landscape-client
