Hi there,
Is it possible to provide custom annotations through the charm pod spec? looking at the base spec it I can’t see anything there.
The same goes for resource limits
Thanks again for the help!
Peter
Hi there,
Peter
Constraints are used to set up minimum mem/cpu resource values but as yet there’s not a way to set maximum limits. We have the same issue with LXD, so it’s something that needs thought generally on how to model.
Annotations on both pods and services are supported.
thanks again @wallyworld!
