Hello,
we have k8s cluster installed with juju:
$ juju status
default my-controller localhost/localhost 2.9.32 unsupported 15:40:19Z
containerd go1.13.8 active 5 containerd stable 178 no Container runtime available
easyrsa 3.0.1 active 1 easyrsa stable 420 no Certificate Authority connected.
etcd 3.4.5 active 3 etcd stable 634 no Healthy with 3 known peers
flannel 0.11.0 active 5 flannel stable 597 no Flannel subnet 10.1.10.1/24
kubeapi-load-balancer 1.18.0 active 1 kubeapi-load-balancer stable 844 yes Loadbalancer ready.
kubernetes-master 1.22.13 blocked 2 kubernetes-master stable 1078 no Stopped services: kube-controller-manager
kubernetes-worker 1.22.13 active 3 kubernetes-worker stable 816 yes Kubernetes worker running.
And I am not sure why the kubernetes-master
has been blocked.
The log says:
Aug 30 15:15:27 my-vm-1 kube-controller-manager.daemon[21627]: I0830 15:15:27.263184 21627 dynamic_serving_content.go:110] "Loaded a new cert/key pair" name="serving-cert::/root/cdk/server.crt::/root/cdk/server.key"
Aug 30 15:15:27 my-vm-1 kube-controller-manager.daemon[21627]: unable to load configmap based request-header-client-ca-file: Unauthorized
Aug 30 15:15:27 my-vm-1 systemd[1]: snap.kube-controller-manager.daemon.service: Main process exited, code=exited, status=1/FAILURE
Aug 30 15:15:27 my-vm-1 systemd[1]: snap.kube-controller-manager.daemon.service: Failed with result 'exit-code'.
Aug 30 15:15:37 my-vm-1 systemd[1]: snap.kube-controller-manager.daemon.service: Scheduled restart job, restart counter is at 28.
Aug 30 15:15:37 my-vm-1 systemd[1]: Stopped Service for snap application kube-controller-manager.daemon.
Aug 30 15:15:37 my-vm-1 systemd[1]: Started Service for snap application kube-controller-manager.daemon.
Aug 30 15:15:37 my-vm-1 kube-controller-manager.daemon[21712]: I0830 15:15:37.987728 21712 feature_gate.go:245] feature gates: &{map[RotateKubeletServerCertificate:true]}
Any hint how can I fix it ?
