In Juju, all Kubernetes clouds behave fundamentally the same.
Notes on juju add-k8s
On Kubernetes clouds, both the cloud definition and the cloud credentials are added through juju add-k8s
, which reads from your kubeconfig file.
Authentication types
certificate
Attributes:
- ClientCertificateData: the kubernetes certificate data (required)
- Token: the kubernetes service account bearer token (required)
- rbac-id: the unique ID key name of the rbac resources (optional)
clientcertificate
Attributes:
- ClientKeyData: the kubernetes certificate key (required)
oauth2
Attributes:
- Token: the kubernetes token (required)
oauth2withcert
Attributes:
- ClientKeyData: the kubernetes private key data (required)
userpass
Attributes:
- username: The username to authenticate with. (required)
- password: The password for the specified username. (required)
Cloud-specific model configuration keys
operator-storage
The storage class used to provision operator storage.
type | string |
default value | “” |
immutable | true |
mandatory | false |
workload-storage
The preferred storage class used to provision workload storage.
type | string |
immutable | false |
mandatory | false |
Supported constraints
See first: Constraint
conflicting: | [instance-type] vs. [cores, cpu-power, mem] |
supported? | |
- allocate-public-ip |
- arch |
- container |
- cores |
- cpu-power |
- image-id |
- instance-role |
- instance-type |
- mem |
- root-disk |
- root-disk-source |
- spaces |
- tags |
Used for affinity. |
- virt-type |
- zones |
Placement directives
Placement directives aren’t supported on Kubernetes clouds.
