Hello together, I am trying to deploy the kubernetes cluster autoscaler via juju into my kubernetes cluster, but the status always shows “waiting” with a message “Container Not Ready”.
kubernetes-autoscaler Ready to Scale waiting 1 kubernetes-autoscaler stable 33 no Container Not Ready
kubernetes-autoscaler/3* waiting idle 3 192.168.22.162 Container Not Ready
There is no pod being created and running juju debug-log only gives the following result:
unit-kubernetes-autoscaler-3: 10:54:47 INFO juju.worker.uniter.operation ran "leader-elected" hook (via hook dispatching script: dispatch)
unit-kubernetes-autoscaler-3: 10:54:48 INFO unit.kubernetes-autoscaler/3.juju-log Missing juju-scale config
unit-kubernetes-autoscaler-3: 10:54:48 INFO juju.worker.uniter.operation ran "config-changed" hook (via hook dispatching script: dispatch)
unit-kubernetes-autoscaler-3: 10:54:48 INFO juju.worker.uniter found queued "start" hook
unit-kubernetes-autoscaler-3: 10:54:49 INFO unit.kubernetes-autoscaler/3.juju-log Running legacy hooks/start.
unit-kubernetes-autoscaler-3: 10:54:49 INFO juju.worker.uniter.operation ran "start" hook (via hook dispatching script: dispatch)
unit-kubernetes-autoscaler-3: 10:55:08 INFO unit.kubernetes-autoscaler/3.juju-log Missing juju-scale config
unit-kubernetes-autoscaler-3: 10:55:08 INFO juju.worker.uniter.operation ran "config-changed" hook (via hook dispatching script: dispatch)
unit-kubernetes-autoscaler-3: 10:55:37 INFO unit.kubernetes-autoscaler/3.juju-log Missing juju-scale config
unit-kubernetes-autoscaler-3: 10:55:37 INFO juju.worker.uniter.operation ran "config-changed" hook (via hook dispatching script: dispatch)
machine-3: 10:54:36 INFO juju.worker.kvmprovisioner machine-3 does not support kvm container
unit-kubernetes-autoscaler-3: 10:54:45 INFO juju.worker.uniter hooks are retried true
unit-kubernetes-autoscaler-3: 10:54:45 INFO juju.worker.uniter.storage initial storage attachments ready
unit-kubernetes-autoscaler-3: 10:54:45 INFO juju.worker.uniter found queued "install" hook
unit-kubernetes-autoscaler-3: 10:54:46 INFO unit.kubernetes-autoscaler/3.juju-log Running legacy hooks/install.
unit-kubernetes-autoscaler-3: 10:54:46 INFO unit.kubernetes-autoscaler/3.juju-log Missing juju-scale config
unit-kubernetes-autoscaler-3: 10:54:47 INFO juju.worker.uniter.operation ran "install" hook (via hook dispatching script: dispatch)
unit-kubernetes-autoscaler-3: 10:54:47 INFO juju.worker.uniter found queued "leader-elected" hook
unit-kubernetes-autoscaler-3: 10:55:51 INFO juju.worker.uniter.operation ran "config-changed" hook (via hook dispatching script: dispatch)
I don’t see any errors, so I have no idea how to debug this. Can anyone help please?
Thank you in advance!
