Hello everyone,
I am troubleshooting an odd behavior between two Kubeflow installations that were both deployed using Juju charms. One installation is on-premise and working correctly, while the second one (hosted on a partner’s VM) fails with 403 or 503 responses at the Istio ingress — even though both deployments appear to have same configuration.
Working Cluster (Local)
- Kubeflow deployed via Juju charms
- MetalLB provides an external IP
I can access the GUI on the browser
Using the IP of the host machine and the 31605 port.
###Broken Cluster (Remote Fedora41 Server)
- Same Kubeflow deployment via Juju
- MetalLB is currently configured with only one IP — the same as the host IP
- Accessing via browser or curl returns:
curl -i http://192.168.1.12:31811
HTTP/1.1 403 Forbidden
server: istio-envoy
I also tried to do curl from a pod inside the same ns, but again I got the same error.
I don’t know how to proceed.
Any ideas?
Thank you !
