The Kratos charmed Operator of the IAM Platform provides integrations to the Canonical Observability Stack.
In this reference we will provide a technical description of the alert rules, and the dashboards the Kratos operator passes to the components of the COS. We will also showcase the Metrics we use to provide observability features.
See more: Charmhub | Kratos > Integrations >
metrics-endpoint,grafana-dashboard
Metrics
up
Description
When this counter equals one, that means the instance the metric was scraped from is available to the Prometheus deployment. If the counter equals zero, or the metric is not present, then the application is inaccessible to the Prometheus deployment.
Source Component
Prometheus
Intended use
This metric signals whether a unit is unavailable. By specifying the label juju_unit this metric tells you whether the unit is available to the Prometheus component or not. Example: up{juju_unit="kratos/0"}
Observed by
- Alert Rules: Rules in group KratosUnavailable
- Dashboard: Kratos Unit Availability
level
Description
All Kratos logs have a level, to indicate the seriousness of an event. Kratos logs (and json formatted logs in general) can be filtered by log levels.
Source Component
Loki
Usage
Use the LogQL’s abilities to enumerate log entries that match a regex template, and to parse json logs and populate fields such as level. Example: {juju_charm="kratos"} | json | level =~ `error`
Observed by
- Alert Rules: Rules in group KratosHighSeverityLog
- Dashboard Visualisation: Kratos High Severity Log Entries
Alert rules
Description
Alerts in this alert group are fired based on how many log entries with the log level of error, critical, or fatal have been created in the last five minutes.
Data Source
Loki
LowFrequencyHighSeverityLog
Description
This alert is fired if the number of interested logs created in the last five minutes is at least one, but no more than one hundred.
Observed failure
The alert does not necessitate a component failure, but could corroborate it.
Severity
Warning. Without other alerts firing, it can be assumed that the deployment does not need human intervention yet.
HighFrequencyHighSeverityLog
Description
This alert is fired if the number of interested logs created in the last five minutes is more than one hundred.
Observed failure
This alert could indicate that some application function is inaccessible due to missing external, or internal dependencies, or misconfiguration. The alert can also indicate that the application is being frequently restarted by the Pebble service because of application errors. Note: This alert can also indicate problems with the client.
Severity
Error. Without other alerts firing, it can be assumed that the deployment is not in imminent danger of loss of service.
KratosUnavailable
Description
Alerts in this alert group observe the up metric of individual Kratos deployment units. In this context, a unit not being available by Prometheus is treated as being inactive. Alerts are fired when units are inactive for at least one minute.
Data Source
Prometheus
KratosUnavailable-one
Description
One unit in a multi-unit deployment is inactive.
Observed failure
An operator instance has encountered an issue from which it can not recover within a minute. The alert also suggests that there are more than one healthy unit in the deployment.
Severity
Warning, because the service itself is still available for the foreseeable future.
KratosUnavailable-multiple
Description
More than one unit in a multi-unit deployment is inactive.
Observed failure
Multiple operator instances have encountered an issue from which they can not recover within a minute. Without other alerts suggesting otherwise, the alert also suggests that there is at least one healthy unit in the deployment.
Severity
Error, because while the service is still available, there is now potential for a critical scenario.
KratosUnavailable-all-except-one
Description
All but one unit in a multi-unit deployment is inactive.
Observed failure
Multiple operator instances have encountered an issue from which they can not recover within a minute. The next such error will result in loss of service.
Severity
Critical. The service is one error away from being inaccessible.
Description
No unit in the deployment is active.
Observed failure
None of the units in the deployment are active. The service is inaccessible.
Severity
Fatal. The service has failed, and can not recover without human intervention.
Dashboards
Description
Visualization for the number of log entries with levels error or above within 5 minutes spans.
Associated Alerts
Alert rules in alert group KratosHighSeverityLog.
Description
Visualization displaying the availability of Kratos units.
Associated Alerts
Alert rules in alert group KratosUnavailable.
Related documentation
A dedicated How-To is available detailing the process of deploying and integrating the IAM Platform bundle and the Canonical Observability Stack bundle.
