This tutorial shows how to set up a fully working kratos server using our charm, MicroK8s and Juju
Set things up
Bootstrap a microk8s controller using juju 3.4 and create a new Juju model:
$ juju add-model kratos
Added 'kratos' model on microk8s/localhost with credential 'microk8s' for user 'admin'
Watch the kratos charm transform the way to deploy, configure, integrate, and manage kratos on any Kubernetes cloud
kratos requires a way to persist data, in the case of our charm we enforce the usage of a postgreSQL database
As mentioned, we need a persistent way to store kratos data, we are going to be using the postgresql-k8s charm
$ juju deploy postgresql-k8s --channel 14/stable --trust postgresql
Deployed "postgresql" from charm-hub charm "postgresql-k8s", revision 193 in channel 14/stable on ubuntu@22.04/stable
Once that is done (no need to wait for it to be ready) we can proceed in deploying kratos and integrate the 2 charms
$ juju deploy kratos --channel 0.2/stable
Deployed "kratos" from charm-hub charm "kratos", revision 399 in channel 0.2/stable on ubuntu@22.04/stable
Integrate with PostgreSQL
$ juju integrate postgresql:database kratos
after some time we should be able to inspect that all has been successfully deployed and connected
$ juju status --relations
kratos microk8s-localhost microk8s/localhost 3.4.2 unsupported 09:45:28+01:00
kratos v1.1.0 active 1 kratos 0.2/stable 399 10.152.183.42 no
postgresql 14.10 active 1 postgresql-k8s 14/stable 193 10.152.183.100 no Primary
kratos/0* active idle 10.1.245.173
postgresql/0* active idle 10.1.245.146 Primary
kratos:kratos-peers kratos:kratos-peers kratos-peers peer
postgresql:database kratos:pg-database postgresql_client regular
postgresql:database-peers postgresql:database-peers postgresql_peers peer
postgresql:restart postgresql:restart rolling_op peer
postgresql:upgrade postgresql:upgrade upgrade peer
Grafana, Loki, and Prometheus
The kratos operator integrates with Canonical Observability Stack (COS) bundle. It comes with a Grafana dashboard as well as Loki and Prometheus alert rules for basic common scenarios. To integrate with the COS bundle, after you deploy it, you can run:
$ juju integrate kratos:grafana-dashboard grafana:grafana-dashboard
$ juju integrate kratos:metrics-endpoint prometheus:metrics-endpoint
$ juju integrate loki:logging kratos:log-proxy
Tear things down
To tear things down, remove the entire kratos model in juju with
juju destroy-model kratos
