Knative on CDK
Hi folks.
Just a note to say how smooth the installation of Knative on CDK was. Works like a charm out of the box following their https://github.com/knative/docs/blob/master/install/Knative-with-any-k8s.md instructions.
I’m gonna try it on microk8s later today or tomorrow and see what the result are there. I’ve got a bunch of data pipelining stuff I wanna test out with Knative and using CDK and hopefully microk8s will make my life much easier.
Tom
Not charm specific but as it was created by Cos might as well go here…
I tested it on microk8s earler and it 99% works, but there is an issue with DNS resolution. In the next week or two I’ll figure it out and then stick a PR into have the ability for users to enable knative within the snap.
