This subordinate charm deploys the Kata untrusted container runtime within a running Juju charm model. It is an open source community working to build a secure container runtime with lightweight virtual machines that feel and perform like containers, but provide stronger workload isolation using hardware virtualisation technology as a second layer of defence.
States
The following states are set by this subordinate:
endpoint.{relation name}.availableThis state is set when Kata is available for use.
Using the Kata subordinate charm
The Kata subordinate charm is to be used with a principal charm and a container runtime subordinate. To use, we deploy the Kata charm and then relate to a principal and a subordinate container runtime.
For example:
juju deploy kata
juju add-relation kata kubernetes-worker
juju add-relation kata:untrusted containerd:untrusted
Scale out Usage
This charm will automatically scale out with the principal charm.
