This page serves to provide instructions on how to start using the kamailio-operator charm.
Quick Start
To test the deploy of the charm locally, use MicroK8s:
# Install/Setup MicroK8s
$ sudo snap install --classic microk8s
$ sudo usermod -aG microk8s $(whoami)
$ sudo microk8s status --wait-ready
$ sudo microk8s enable storage dns ingress
$ sudo snap alias microk8s.kubectl kubectl
$ newgrp microk8s
# Install Charmcraft
$ sudo snap install charmcraft
# Install Juju 2.9+
$ sudo snap install juju --classic
# Bootstrap MicroK8s
$ juju bootstrap microk8s micro
$ juju add-model development
# Build the charm and deploy
$ git clone https://github.com/gmeszaros/charm-kamailio
$ cd charm-kamailio
$ charmcraft pack
$ juju deploy ./kamailio_ubuntu-20.04-amd64.charm --resource kamailio-image=kamailio/kamailio:5.3.3-stretch
$ juju deploy nginx-ingress-integrator --config ingress-class="public"
# Relate kamailio and ingress integrator
$ juju add-relation kamailio nginx-ingress-integrator
# Add an entry to /etc/hosts
$ echo "127.0.1.1 kamailio.juju" | sudo tee -a /etc/hosts
# Wait for the deployment to complete
$ watch -n1 --color juju status --color
Debugging
Create a bash session to inspect the kamailio container with:
$ kubectl -n development exec -it -c kamailio kamailio-0 -- bash
Testing
# Install python3-virtualenv
$ sudo apt update && sudo apt install -y python3-virtualenv
# Create a virtualenv for the charm code
$ virtualenv venv
# Activate the venv
$ source ./venv/bin/activate
# Install dependencies
$ pip install -r requirements-dev.txt
# Run the tests
$ ./run_tests
Publishing and Releasing a new version
See Juju | Publishing and Juju | Resources for additional documentation. As a short summary:
$ charmcraft login
$ charmcraft pack
$ chamcraft upload
# be sure to also git commit/code review/push to the upstream
# source so the changes are in version control
