Is it possible to specify a custom charm store url?
The specific case is an offline install where there is only 1 “proxy-like” system allowed. Everything in the proxy must be explicitly defined and put at a subdirectory - aka proxy.com/landscape/ is where the debs for Landscape sit.
Alternatively a better process for managing the charms we need in the environment would help. Currently it’s:
- Charm pull all 30+ charms
- tar them
- Move them to environment and use them there.
- Upgrade them one at a time.
(Parts of this are scripted)
We lose a lot of context doing it this way. None of the charms have to be modified locally.
Hi @bryanquigley, yes it is possible. The charmstore-url controller configuration parameter is what you might be looking for.
$ juju controller-config charmstore-url
https://api.jujucharms.com/charmstore
However, you might want to first look at the proxy options in the model configuration parameters:
$ juju model-config -m controller | grep proxy
apt-ftp-proxy default ""
apt-http-proxy default ""
apt-https-proxy default ""
apt-no-proxy default ""
juju-ftp-proxy default ""
juju-http-proxy default ""
juju-https-proxy default ""
juju-no-proxy default 127.0.0.1,localhost,::1
proxy-ssh default false
snap-http-proxy default ""
snap-https-proxy default ""
snap-store-proxy default ""
snap-store-proxy-url default ""
