I have deployed openstack/base on MaaS as indicated here. After I tried to deploy charmed-kubernetes with an openstack-integrator and vault overlay, I cannot perform openstackclient commands on the maas node and the images uploaded to the dashboard are not recognized, that means, the ubuntu charms cannot be deployed. When I do, for example,
openstack catalog list
I get
Failed to discover available identity versions when contacting https://keystone_ip:5000/v3. Attempting to parse version from URL.
SSL exception connecting to https://keystone_ip:5000/v3/auth/tokens: HTTPSConnectionPool(host=‘keystone_ip’, port=5000): Max retries exceeded with url: /v3/auth/tokens (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1108)’)))
However, when I ssh into the keystone container, there is a keystone_juju_ca_cert.crt which has as
Issuer: CN = Vault Root Certificate Authority (charm-pki-local)
and as
Subject: CN = Vault Root Certificate Authority (charm-pki-local)
I have also tried to reissue the certificates and refresh the secrets through actions in the vault application, but to no avail.
Can somobody help me here ? By this point, this is already the second bigger problem I have with certificate management using vault. Is there a more comprehensive guide with more detailed information ?
