Juju Terraform provider 1.5.7 release notes
8 September 2026
Requirements and compatibility
- This release requires a Juju controller of version 2.9 or higher.
- If you are using JAAS, this release requires a Juju controller of version 3.6.5 or higher.
- This release builds against the Juju client API code from the Juju 3.6.25 branch.
Bug fixes
- Terraform apply with change in base results in error â updating the base for a Kubernetes charm is supported by Juju but returns an error in the provider if the charm revision is not specified. Tweak revision invalidator modifier by @kian-parvin in #1357 (addresses #1351).
Documentation
- Document how to use the controller model by @simonedutto in #1301.
Full changelog: https://github.com/juju/terraform-provider-juju/compare/v1.5.6âŠv1.5.7
