The Juju team is happy to announce that the Juju Terraform provider v1.4.1 is released on 31 March 2026!
NOTE: There was an issue with Hashicorp’s Terraform registry, which did not ingest the release, but it is available in the OpenTofu’s registry. We are trying to resolve the issue with Hashicorp (IBM) support. Edit: A fix has been applied and v1.4.2 released in place of v1.4.1.
To use the new version of the provider update your provider configuration to:
terraform {
required_providers {
juju = {
source = "juju/juju"
version = "1.4.1"
NEW FEATURES
This release introduces a few new features to the Juju Terraform provider:
- The new
juju_jaas_controllerresource can be used to add a Juju controller to JAAS (see documentation). - The
enable-haTerraform action that can be used with thejuju_controllerresource to put it in HA mode (see documentation). - The Juju Terraform provider now supports exporting model to Terraform plans (see documentation).
- The
juju_charmdata source can be used to fetch information about a specific charm (see documentation
LINKS:
NOTES:
- The
enable-haand model export features require Terraform 1.14, which is already available as a snap instablechannel. - This release requires Juju controller version 2.9.49 or higher Juju.
- If using JAAS, this release requires Juju controller version 3.6.5 or higher.
- This release uses Juju client api code from the Juju 3.6.11 release.
ENHANCEMENTS
- Add model export support via
terraform queryby @SimoneDutto in #1053 - Implement machine listing to support export flows by @alesstimec in #1072
- Implement offer listing for export generation by @kian99 in #1077
- Implement SSH key listing for export by @ale8k in #1074
- Add application export support by @ale8k in #1078
- Add
enable-haaction support and controller HA enablement by @SimoneDutto in #1087 and #1081 - Add integration export support by @luci1900 in #1089
- Add storage pool export support by @ale8k in #1092
- Add secrets export support by @ale8k in #1097
- Introduce the
juju_jaas_controllerresource by @kian99 in #1099 - Add wait-for logging to improve provider diagnostics during long operations by @kian99 in #1115
- Add
juju_charmdata source by @SimoneDutto in #1123 - Pass process environment variables to Juju command runner for improved runtime compatibility by @kian99 in #1130
BUG FIXES
- Fix JAAS export user detection by returning client ID from
GetUser()when connected to JAAS by @SimoneDutto in #1084 - Fix provider behavior to honor
http_proxy,https_proxy, and related proxy variables by @SimoneDutto in #1103 - Use
addErrorinstead ofaddWarningwhen controller import cannot read remote details by @kian99 in #1128
DOCUMENTATION
- Document the new
enable-haaction by @SimoneDutto in #1098 - Add examples for
juju_controllerandjuju_jaas_controllerresources by @kian99 in #1114 - Add
juju_charmuse-case documentation by @SimoneDutto in #1125 - Add export feature docs and associated fly-by documentation fixes by @SimoneDutto in #1127
- Add a how-to for exporting a model by @SimoneDutto in #1132
- Refactor and clean up controller management docs after bootstrap changes by @tmihoc in #1131
CI & MAINTENANCE
- Update Trivy GitHub Action version in CI by @alesstimec in #1120
- Merge
maininto feature branch during release work by @SimoneDutto in #1106 - Merge
v1.3branch back intomainto align release history by @kian99 in #1109 - Merge
mainduring final release synchronization by @SimoneDutto in #1135 - Merge
feature/exportintomainby @SimoneDutto in #1138
Full Changelog: Comparing v1.3.1...v1.4.1 · juju/terraform-provider-juju · GitHub
