A while ago, I was messing with juju ssh and ssh-agent (needed for some bootstrap activities) and now I can’t seem to recover the ability to do “juju ssh”.
I think this is related to the juju snap, but I can make this work prior to me messing with the ssh-agent.
Is there anyone that knows more about or has some pointers on this topic?
@jameinel helped me out on the ssh-agent which I havent been able to resolve.
The issue, as I understand it, is that by default if you just run ssh-agent it will set itself up with a socket under /tmp/* which is accessible by your user account, but not from within a confined snap, where /tmp gets rebound to a per-snap directory.
What I use is:
eval `ssh-agent -a $HOME/dev/tmp/ssh-XXXXX`
It needs to be under $HOME, and not a hidden (.) directory. Then that should be the same directory from inside the snap as outside the confined snap.
