Hi folks, could you please change the owner of the juju-qa-pebble-notices charm to “Juju Engineering”?
This is a charm being used by Juju integration tests. See https://github.com/juju/juju/pull/16428 for more context.
Thanks!
Thanks!
Hi,
Can you please tell us the exact username of the intended recipient? I wasn’t able to find any user/ LP account by that name.
Thanks,
Odysseus
It should be the same username as this charm: https://charmhub.io/juju-qa-appdata-sink
It shows up as “Juju Engineering”, but I guess that’s the display name. It looks like the username is just “juju”: Juju Engineering in Launchpad
Hi,
This is done. For future travelers, the correct username was team-juju.
Thanks,
Odysseus
