Hi everyone!
This is the pulse report for the Juju team (16 Jan - 27 Jan).
Our goal for this pulse
Fix bugs and check CI issues to polish 3.1.0 release.
Task
- Community workshop Jan 27 (secrets, olm side)
- Community workshop Jan 26 (advanced debugging with jhack)
- Terraform night build for 2.9
- Add test-model-test-model-status to 2.9
- Community workshop Jan 20 (write your first machine charm)
- Adjust how prompts default in 3.2
- Cleaned up, restructured, reclassified doc on authentication with Dex. Updated ref doc on Dex.
- Initial review: New HTG: How to access object storage using MinIO
- Design template for component Ref docs, create docs, apply template
- Finish removal of “cs:” in unit tests
- Change link to release notes on release jenkins
- Add night build checks for python-libjuju 2.9 branch
- Experiment with MAAS custom image selection
- Create jenkins job to build dqlite
- Allow building dqlite locally
- Add support for secrets
- Provide updates to JU059 spec. Prepare a biweekly discussion with the SmartNIC team.
- Release python-libjuju 2.9.12 with support for juju 2.9.38
- update charm pkg version in juju to 10
- Community Workshop, Americas 19-Jan-23
- Remove charmstore charm support from pylibjuju
Bug
- Status makes CAAS-only calls for IAAS applications
- Downgrade juju client to 2.9.37
- Charm upgrade series hook uses base instead of series
- Fix panic on config change
- fix incorrect change for lp1984061, migration import adding “latest” to charm origin channel
- ‘juju-db.mongodump’ doesn’t have apparmor permissions to write log files to $HOME
- 1982870: lxd/1+ unit agents down after migration,
- Fix test-ck-aws
- juju using Openstack provider does not remove security groups on remove-machine after a failed provisioning
- root cause of LP2002114 (panic due to application charm url being nil)
- Autocompletion of channel in empty model
- Fix test-storage-test-persistent-storage-aws
- deploy sidecar charm from ch will get an error in model log
- panic when getting juju full status
- Juju doesn’t mount storage after lxd container restart
- Cannot bootstrap in airgapped LXD environment
- Fix
juju status --integrations - juju generates/uses insecure ssh keys
- LP1999060 failures with multi app single charm bundles
- MAAS+TLS error opening environ
