Hi all, I’ve been following the OpenStack Charms Deployment guide. Yesterday I managed to have an OpenStack cloud completely working, but our data center had a Power Outage and the MySQL InnoDB Cluster is stuck in the following state:
mysql-innodb-cluster/0* blocked idle 0/lxd/0 10.12.31.222 Cluster is inaccessible from this instance. Pleas
e check logs for details.
mysql-innodb-cluster/1 blocked idle 1/lxd/0 10.12.31.224 Cluster is inaccessible from this instance. Pleas
mysql-innodb-cluster/2 blocked idle 2/lxd/0 10.12.31.223 Cluster is inaccessible from this instance. Pleas
I’ve read the Managing Power Events page and tried all these commands:
$ juju run mysql-innodb-cluster/0 reboot-cluster-from-complete-outage
Running operation 179 with 1 task
- task 180 on unit-mysql-innodb-cluster-0
Waiting for task 180...
ERROR timed out waiting for results from: unit mysql-innodb-cluster/0
$ juju run mysql-innodb-cluster/1 reboot-cluster-from-complete-outage
Running operation 185 with 1 task
- task 186 on unit-mysql-innodb-cluster-1
Waiting for task 186...
Action id 186 failed: Reboot cluster from complete outage failed.
output: |+
Cannot set LC_ALL to locale en_US.UTF-8: No such file or directory
Restoring the default cluster from complete outage...
File "<string>", line 2, in <module>
RuntimeError: Dba.reboot_cluster_from_complete_outage: The active session instance (10.12.31.224:3306) isn't the most updated in comparison with the ONLINE instances of the Cluster's metadata. Please use the most up to date instance: '10.12.31.222:3306'.
traceback: |
File "/var/lib/juju/agents/unit-mysql-innodb-cluster-1/charm/actions/reboot-cluster-from-complete-outage", line 164, in reboot_cluster_from_complete_outage
output = instance.reboot_cluster_from_complete_outage()
File "/var/lib/juju/agents/unit-mysql-innodb-cluster-1/charm/lib/charm/openstack/mysql_innodb_cluster.py", line 947, in reboot_cluster_from_complete_outage
raise e
File "/var/lib/juju/agents/unit-mysql-innodb-cluster-1/charm/lib/charm/openstack/mysql_innodb_cluster.py", line 935, in reboot_cluster_from_complete_outage
output = self.run_mysqlsh_script(_script).decode("UTF-8")
File "/var/lib/juju/agents/unit-mysql-innodb-cluster-1/charm/lib/charm/openstack/mysql_innodb_cluster.py", line 1723, in run_mysqlsh_script
return subprocess.check_output(cmd, stderr=subprocess.PIPE)
File "/usr/lib/python3.10/subprocess.py", line 421, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/snap/bin/mysqlsh', '--no-wizard', '--python', '-f', '/root/snap/mysql-shell/common/tmp8_l6tvzc.py']' returned non-zero exit status 1.
$ juju exec --unit mysql-innodb-cluster/leader leader-get mysql.passwd
Since I can’t get password to connect to the cluster I couldn’t try solutions like this.
Thanks in advance for any help you can give me!
