Howdy,
First time deploying openstack and doing some research I figured using Juju was the most easy way to get started. However, I’m getting an error when trying to deploy it.
When typing juju status during the initial deployment I’ve noticed that the mysql cluster is failing on one node and ‘waiting for machine.’
mysql-innodb-cluster/0* waiting idle 0/lxd/0 172.16.7.34 'cluster' incomplete, Not all
instances configured for clustering
mysql-innodb-cluster/1 waiting idle 1/lxd/0 172.16.7.35 'cluster' incomplete, Instance
not yet configured for clustering
mysql-innodb-cluster/2 waiting allocating 2/lxd/0 waiting for machine
I ssh’d into the machine to check the logs, and the juju machine log shows:
020-12-11 08:01:28 INFO juju.container-setup container_initialisation.go:109 initial container setup
with ids: [2/lxd/0]
2020-12-11 08:01:28 INFO juju.packaging.manager utils.go:64 Running: snap info lxd
2020-12-11 08:01:28 INFO juju.container.lxd initialisation_linux.go:295 LXD snap is already installed
(channel: latest/stable); skipping package installation
2020-12-11 08:01:28 WARNING juju.container-setup container_initialisation.go:138 not stopping
machine agent container watcher due to error: setting up container dependencies on host
machine: Get "http://unix.socket/1.0"
: dial unix /var/snap/lxd/common/lxd/unix.socket: connect: connection refused
2020-12-11 08:01:28 ERROR juju.container-setup container_initialisation.go:117 starting container
provisioner for lxd: setting up container dependencies on host machine: Get
"http://unix.socket/1.0": dial unix /var/snap
When I type LXD it shows this:
EROR[12-11|08:47:37] Failed to start the daemon: failed to open cluster database: failed to ensure
schema: failed to update node version info: updated 0 rows instead of 1
So now the deployment is completely stuck. So question is how can I fix this and move forward.
Thanks!
